Replacing rear axle seal and already have 1 piece axles from previous owner - JeepForum.com
post #1 of 6 Old 07-01-2014, 10:26 PM Thread Starter
seabass1858
1983 CJ7
I am getting tired of topping off my rear diff once a week for 14 weeks I been here. I have been putting it off all this time because I don't want to get in over my head. I need to know if I can replace the rear axle seal with just the hand tools I have in a parking lot. I do have a seal puller. I do not know when the 1 piece axles were installed and I do not know what brand the they are.
seabass1858 is offline
post #2 of 6 Old 07-02-2014, 07:29 AM
grasmo
1982 CJ5
you should be fine if replacing just the inner seal.
grasmo is offline
post #3 of 6 Old 07-02-2014, 08:35 AM Thread Starter
seabass1858
1983 CJ7
ill use my front spindle nut socket to tap the new one into place
post #4 of 6 Old 07-02-2014, 10:00 AM
CJ7VFR
Take a stab at it. The one piece axles are ALOT easier to work
with than the two piece factory ones!
Jim
CJ7VFR is offline
post #5 of 6 Old 07-02-2014, 10:06 AM
grasmo
1982 CJ5
go down to carquest or napa and get a 'bearing & seal' driver kit. the lisle kit is fine and cheap. you'll be glad you did. this is the small set:
http://www.lislecorp.com/divisions/p...n=1&category=7
grasmo is offline
post #6 of 6 Old 07-03-2014, 03:14 AM
80cj
80cj's Avatar
1980 CJ5
Hope the bearing spacer ring is not stuck in the housing. Happens sometimes.
80cj is offline
