replacing ignition control module and coil - Page 2 - JeepForum.com
post #16 of 27 Old 03-04-2013, 02:20 PM
86cj74.2L
86cj74.2L's Avatar
Any can type coil with the ford terminals will work.
86cj74.2L is offline
post #17 of 27 Old 03-04-2013, 10:47 PM
bigbird24
3.0 OHM or 1.5 OHM doesn't make a difference?
bigbird24 is offline
post #18 of 27 Old 03-04-2013, 11:12 PM
BagusJeep
1981 CJ7
The coil is a standard 12V BALLASTED coil. It normally runs at 7V and in Start it gets 12V for a few seconds.
Lots of vendors selling coils with all sorts of fantastic claims but it is a bog standard sub $20 piece of kit.
I have a Mallory Promaster coil ($96) that will take a lot of punishment but in reality any new coil will work better than that old one.
And that thing on the side is to reduce radio interference, not vital but useful.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #19 of 27 Old 03-05-2013, 04:27 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Kind of, the coil winding in the higher performance coils usually have a lower resistance so using a 3 ohm ballast resister might drop the voltage too low on the coil. the 1.5 ohm will raise the voltage but allow more current to run through it and could overheat the ICM.
The resistance wire in a stock jeep is 1.35 ohms.
John Strenk is online now
post #20 of 27 Old 03-05-2013, 04:03 PM
bigbird24
The new wiring harness and weber carburetor have made the icm useless so it has been removed. which still leaves me with the question of which to use, sorry but I'm new to this
post #21 of 27 Old 03-05-2013, 04:43 PM
86cj74.2L
86cj74.2L's Avatar
If your just looking to replace the coil with a OEM coil just go to the parts store and get a new coil for a 80's CJ with a 258.
Is yours bad or you do not like the rust?
post #22 of 27 Old 05-15-2015, 05:39 PM
Marlen
I have some trouble identifiying and matching the colors present in my CJ7 1982 258 when changing the ICM. Original cables differ in color with the ones in the new part and also the plugs to connect it differ.
I have some pics but really dont know how to upload them
I would appreciate some help on this
Marlen is offline
post #23 of 27 Old 05-15-2015, 05:47 PM
Marlen
Her some photos that follow the previous post
Marlen is offline
post #24 of 27 Old 05-15-2015, 05:52 PM
Marlen
Here, finally the pics
Marlen is offline
post #25 of 27 Old 05-16-2015, 05:53 AM
Mike Romain
That is not an ICM, that is an idle speed controller for the stepper motor on the back of the carb that adjusts the mix according to inputs from things like the O2 sensor.
Your ICM is way down on the drivers side fender under the washer bottle.
Mike
Mike Romain is offline
post #26 of 27 Old 05-16-2015, 05:56 AM
ColdSteel85
1982 CJ7
There is a difference between "idle" control box and the "ignition" control. The idle control box as I understand is a pre ECM type of computer that largely has to do with emissions control. Someone please correct me if I'm wrong. Jeeps 82 and older had the idle speed control box where as 83 and later had the ECM. The idle control mounts to the passenger gender where the ignition control mounts to the driver fender. If your idle control box is somehow broken you will probably have a hard time finding a replacement. There are some threads that deal with bypassing the idle control box all together. In my 82 I have removed mine and all the associated wiring but still have a lot of work to do before I wire everything back and try and start. Hope this helps.
ColdSteel85 is offline
post #27 of 27 Old 05-16-2015, 06:42 AM
Mike Romain
If your idle control box is cooked, you can just set the stepper motor pins in the center of their travel with 1/8" of shaft showing from the back wall before the taper. Your carb will then act like a pre-stepper BBD and be good to go. That setting is important for gas mileage as it controls the mix.
Mike
ignition coil , ignition module
what are the symptoms of failing ignition control module? Brg0012 Jeep CJ Forum 33 06-11-2017 10:17 AM
Wiring For the Ignition Control Module jpd1899 Jeep CJ Forum 1 12-18-2010 06:01 PM
Ignition Control Module location change... coach_rose Jeep CJ Forum 11 03-07-2010 05:34 PM
Ignition Control Module G Watts Jeep CJ Forum 7 11-22-2008 07:23 AM
Ignition COntrol Module vocky Jeep CJ Forum 5 10-10-2007 07:03 PM
