Replacing Clutch Pedal Return Spring - JeepForum.com
post #1 of 26 Old 09-10-2010, 12:26 PM Thread Starter
SuperSportCJ
1982 CJ7
Is there a trick to replacing the clutch pedal return spring up under the dash? I bought a new one because the one on there now squeaks everytime I push the clutch and it sounds like an old screen door opening and closing. It just seems so stiff that I don't know how I'm going to get the old one off and the new one on.
SuperSportCJ is offline
post #2 of 26 Old 09-10-2010, 12:49 PM
Coiz
1979 CJ7
To get the old one off you'll probably have to cut it. To get the new one on, the service manual has you drill a hole in the firewall, attached wire to the spring, run the wire through the hole and attach to a 2x4 under the hood to use as a pry bar to pull the spring onto the bracket. There is a good picture of the process floating around here somewhere.
I attached mine with the pedals out of the vehicle and it was still a major PITA. That spring is under a lot of tension. I used the tool you use for drum brake springs and had to use a two foot breaker bar on the end of that to have enough leverage to get it on.
Have you considered zip-tieing a piece of rubber or something else around the current spring to stop the noise?
Mike
Coiz is offline
post #3 of 26 Old 09-10-2010, 12:52 PM
Torxhead
I'm pretty sure that squeaking is caused from the bearing that the clutch pedal rotates on. Have fun lubricating it. I hope somebody can tell me how to do this without complete disasembly. I installed a lube jerk up in there once but it works poorly. I also installed hoses around the clutch return spring ends.
After reading Coiz's post I appears that some changes have been made over the years. I guess my setup is a lot different.
Torxhead is offline
post #4 of 26 Old 09-10-2010, 01:00 PM
Coiz
1979 CJ7
This is the pedal set up I was working with.
You may be right that the noise could be from the pivot bearing for the pedal itself.
Mike
Coiz is offline
post #5 of 26 Old 09-10-2010, 01:24 PM Thread Starter
SuperSportCJ
1982 CJ7
That looks to be the same set up that I have. I'll try the hose over the spring first. The way the squeak sounds I am pretty sure its the spring but not positive. It gets higher pitched as the spring stretches and gets lower as it retracts when the petal moves over-center. How hard is it to just remove the whole assembly as you have done?
post #6 of 26 Old 09-10-2010, 04:05 PM
keith460
Jeep. There's Only One
keith460's Avatar
I don't think for 1982 model year CJ that the spring attaches the same way that Coiz's shows. Your spring may be mounted to the pedal arm as shown in the photo below.
Squeaking noise should not becoming from the pedal assembly pivot bushing either unless it is severely worn. The bushings are of the Oilite type and are lubricated for life due to the oil impregnated into the bronze alloy during manufacturing process of the bushings. Maybe the noise is coming from the clutch rods themselves since the factory units are steel against steel and usually wear out over time and could be the cause of your noise. I've added Oilite bushings for new clutch rods for all the clutch rod pivot points shown by the arrow in the photo and to the bellcrank mounted to the firewall and bellhousing.
1984 CJ-7 Renegade
keith460 is offline
post #7 of 26 Old 09-10-2010, 04:22 PM
Coiz
1979 CJ7
Hey Kieth,
I'm assuming you had to drill out the hole to make the bushing fit. Any info on where you got them, part number, cost, ect.,.? Are they considered soft metal? The holes in the steal pedal and bell crank get distorted with normal use. Wondering if those are softer and going to be more prone to wear faster. Thanks.
Mike
Coiz is offline
post #8 of 26 Old 09-10-2010, 04:44 PM
keith460
keith460's Avatar
Got the bushings from McMaster-Carr for about .55 cents a piece and they are Part Number: 6338K414
Here's the specs on them: Oilite Bushing
Material: Bronze
Bronze Type: SAE 841 Bronze
Type: Flanged Sleeve Bearings
For Shaft Diameter (Inside Diameter): 3/8"
Inside Diameter Tolerance: +.0010" to +.0020"
Outside Diameter: 1/2"
Outside Diameter Tolerance: +.002" to +.003"
Flange Outside Diameter: 11/16"
Flange Thickness: 1/16"
Length: 1/4"
Length Tolerance: .005"
Load (P Max): 2,000
Speed (V Max): 1,200
Load at Speed (PV Max): 50,000
Temperature Range: +10 to +220 F
Specifications Met: Not Rated
And yes, had to drill the holes to 1/2" diameter but they work great as I did this back in 1993 and they show no signs of wear at any of the pivot points.
1984 CJ-7 Renegade
keith460 is offline
post #9 of 26 Old 09-10-2010, 08:30 PM
brandon20
glad i read this board. i just ordered a clutch return spring and i thought it was for the spring under the jeep not inside it. heres the diargram from morris 4x4 Jeep Clutch Parts for Jeep CJ5, CJ7, CJ8, Scrambler at Morris 4x4 Center. i bought # 25 which is the spring this forum is talking about. my spring near the clutch linkaga system under the jeep that moves with the clutch pedal is all rusted. does anyone # what spring this is and have alink for it? thanks
brandon20 is offline
post #10 of 26 Old 09-11-2010, 08:49 AM
brandon20
bump. does anyone know the answer to the above question. thanks
post #11 of 26 Old 09-11-2010, 09:25 AM
keith460
keith460's Avatar
Items #6 and #12 are the only other springs in the clutch linkage system besides #25 for the pedal return shown in the Morris4x4 website diagram.
1984 CJ-7 Renegade
keith460 is offline
post #12 of 26 Old 09-11-2010, 10:10 AM
80cj
80cj's Avatar
1980 CJ5
This is the procdure for clutch pedal spring replacement from my 1980 Jeep FSM. It involves drilling a hole in the firewall and using wire and 2x4's to pull the spring over the end of the clutck pedal. I used the procedure to replace my spring. Worked geat.
80cj is offline
post #13 of 26 Old 10-26-2010, 06:53 AM Thread Starter
SuperSportCJ
1982 CJ7
Hey just saw this post about the 2x4 and wire. I'm going to try this tonight. Thanks for the info, I'll let you know how it goes!
post #14 of 26 Old 10-26-2010, 07:46 AM
ddumbauld
1982 CJ7
I've got the exact same squeaking noise coming from the clutch pedal assembly. Pitch of noise increases as pedal get closer to the floor. I'm anxious to hear if the spring replacement works.
ddumbauld is offline
post #15 of 26 Old 10-26-2010, 08:25 AM
Pog
Pog's Avatar
The spring setup on my '84 is just like the one in the picture Keith provided. I replaced the spring to help improve sloppy pedal return, and the noise was actually worse with the newer spring. However, I encountered it with both.
I decided to try a trick I found when building my guitar and it silenced it completely. A gent on YouTube was kind enough to provide a video of the procedure. Watch it and you'll get the idea.
YouTube - Strat Spring Silencing Trick
You can also add a little light oil or grease to the foam strip to improve the dampening even further.
Regards
Pog is offline
Clutch pedal return spring Mjbb04 Jeep CJ Forum 10 08-05-2016 01:47 PM
'81 CJ Clutch Pedal Return Spring Woes RARECJ8 Jeep CJ Forum 5 06-28-2011 09:07 AM
Brake Pedal Return Spring ? pu70 Jeep CJ Forum 3 09-09-2008 08:06 AM
clutch pedal return spring? wjb4000 Jeep CJ Forum 3 02-07-2008 06:17 AM
Clutch Pedal Return Spring Fustration big G Jeep CJ Forum 8 03-09-2007 07:54 PM
