replacing the brakes in my 1960 cj5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > replacing the brakes in my 1960 cj5
Dual Color LED Light Bars White/AmberTJ 5.25" Speaker Adapters - NalinMFGAlloy USA Still Available
Unread 07-09-2014, 01:09 PM   #1
jessecj5
I need to know if the brakes are 9 inch or 10 inch on my jeep so i can order the parts. I can't get the drum off to measure so if anyone has a trick to get to get it off that would be awesome. I already broke it free with a hammer but can't pull it off and can't pry if off because there is the backing plate all the way around. Or is there something i can look up with the vin number to find out.
jessecj5 is offline   Reply With Quote
Unread 07-09-2014, 01:52 PM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Usually you have to come from behind through a slot and turn a star wheel inside to unadjusted them before they come off. They wear a ridge in the drum and adjust into it.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote
Unread 07-09-2014, 06:53 PM   #3
Unretarded
Unretarded's Avatar
1963 CJ5
The star wheel slot is located at the bottom center.......a flat head screw driver will turn it....it turns up and down.....one way pulls the pads together allowing you to remove the drum and the other will make the pads tight against the drum.
Jeep...the first vehicle on the moon.....next trip we are bringing the tub!
It is gunna cost more and take longer than you thought...plan ahead!
Unretarded is offline   Reply With Quote
