Replacements for Liquid Check Valve/Roll Over valve - Page 2 - JeepForum.com
post #16 of 144 Old 03-07-2009, 06:40 PM
cincyjeeprs
Originally Posted by jscherb View Post
Well if they run out, check out your local Nissan dealer - the black rollover check valve in the lower left of this photo is from a mid-90's Nissan Altima. Only real difference is the way it mounts, which is why the zip tie.
I got mine earlier this week, but haven't installed it yet. Two questions though.
1. The diagram shows the hose from the fluid check valve to the lower nipple of the roll over valve. Your picture shows it to the top nipple of the roll over valve. Which is correct?
2. What year is the Nissan Altima application, and is it available aftermarket, or dealer?
cincyjeeprs is offline
post #17 of 144 Old 03-07-2009, 06:53 PM
jscherb
The Nissan valve is marked, see this photo. I got mine from a 93 or 94 Altima, but it is probably used in more years than that.
"Whether you think you can do something or you think you can't, you are right" - Henry Ford
jscherb is offline
post #18 of 144 Old 03-07-2009, 07:30 PM
cincyjeeprs
Hmm. Interesting. It looks like the Delorean part is opposite of the Nissan. It has the the bottom nipple labeled "Tank" and the top nipple labeled "can vent", so the diagram would be correct. The Nissan must be different internally.
Just to add to the intrigue, the top of the Delorean part is embossed with the Chrysler pentastar logo and has the number 04091. There is also the number 4002012 on the bottom of the part. IIRC, Deloreans were just like Jeeps - they sourced parts from everywhere.
post #19 of 144 Old 03-07-2009, 08:23 PM
keith460
Jeep. There's Only One
keith460's Avatar
Yes, I see those markings also which tells me that the Rollover Check Valves should still be available from Chrysler Parts dept. The bottom No. 4002012 is probably part of the P/N and I'll have my buddies over at Chrysler try to decipher it for us.
When you get the Rollover Check Valve mounted up, pictured below is what you should end up with.
1984 CJ-7 Renegade
keith460 is offline
post #20 of 144 Old 03-08-2009, 06:41 PM
cincyjeeprs
Exxxxxxxcelent!
post #21 of 144 Old 03-08-2009, 09:03 PM
John N
1981 CJ8
OK, I ordered 2 of the roll-over valves. Who's a good source for the liquid check valves?
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #22 of 144 Old 03-17-2009, 09:07 AM
Truck
I wish I'd of known you were going to order John, I'd of asked you to throw a couple extra for me. Seems shipping is as much as the part.
Anybody in NoVA want to go in on several and split shipping?
Truck
83 Scrambler, bought in 94, basically stock except full hard top, 32" tires, bumpers and nerfs...starting to rust away, partially due to neglect, partially due to environment (Alaska, England, Florida)..."we can rebuild him" Now in pieces all over the garage
82 Scrambler, bought in 05, chevy 305, TH 350 auto, 205 transfer case, 9" rear
86 CUCV Maintanance truck w/12KW PTO driven generator and air compressor
95 Wrangler
83 Scrambler, almost bone stock with 151 Iron Duke, thinking about daily driver/restoration project
Truck is offline
post #23 of 144 Old 03-17-2009, 05:48 PM
John N
1981 CJ8
Truck
Sorry, I got 2, but figure I'll use both on my CJ's eventually.
John N
John N is offline
post #24 of 144 Old 03-17-2009, 06:24 PM
scottymac62
1979 CJ7
Great find! I just ordered 2 of them
scottymac62 is offline
post #25 of 144 Old 03-17-2009, 07:17 PM
Axlesnap
1975 CJ5
Missing rollover
great Info! QUESTION... since I am in the process of re-installing my evap to decrease petrol fumes, I peeked under and only see the liquid check valve, no roll over valve..did all 1976 come with them? also my tank has be replaced and has one vent..should I just put in a Y to connect to the two lines in the check valve
Axlesnap is offline
post #26 of 144 Old 03-27-2009, 10:51 PM
VACJ7
VACJ7's Avatar
I got the rollover valve but coming up empty on the liquid check valve to complete my swap to the 15 gal tank. Why couldn't you use two of these off the tanks vents, then T back to one hose to the rollover valve? The check valve just lets gas fumes to pass and prevents gas from traveling up the lines, correct?
http://www.hho4fuelstore.com/1pplichva1.html
VACJ7 is offline
post #27 of 144 Old 03-27-2009, 10:59 PM
mcmud
1983 CJ8
Maybe this link will provide you one.
http://www.willys.net/html/fuel.html
mcmud is offline
post #28 of 144 Old 03-27-2009, 11:26 PM
VACJ7
VACJ7's Avatar
Yeah, he's out. These things are hard to come by...
VACJ7 is offline
post #29 of 144 Old 03-28-2009, 06:34 AM
hold24
1977 CJ7
Kieth were did you get those fuel line clips? I need some of those. I also just received 2 of those role over check valves
1978 cj7 Black Renegade levis ....304 3spd hardtop ps pb tilt tac and clock ac...
1979 cj7 Cumberland green Golden Eagle 18k Original miles V8 auto..100% rust free Oregon Jeep..
hold24 is offline
post #30 of 144 Old 03-28-2009, 07:24 AM
keith460
keith460's Avatar
Originally Posted by hold24 View Post
Keith were did you get those fuel line clips? I need some of those. I also just received 2 of those role over check valves
I got some from NAPA and or AutoZone, the rest of my original OEM's I sandblasted and powder coated.
You can also get them from here: http://www.inlinetube.com/ listed in the side bar index under Brake Clips and Clamps.
1984 CJ-7 Renegade
keith460 is offline
CJ - Liquid Check Valve - HELP RangerOne Jeep CJ Forum 2 08-24-2009 07:20 AM
I need a Liquid Check Valve meater Jeep CJ Forum 2 04-11-2008 03:49 PM
Liquid Check Valve longlimb Jeep CJ Forum 19 11-11-2006 09:13 PM
Gas check valve and anti roll over valve ? NCHornet Jeep CJ Forum 1 10-10-2006 06:18 PM
