Replacement windshield recommendations? - JeepForum.com
post #1 of 6 Old 09-11-2011, 02:56 PM Thread Starter
mknherhappy
I need to replace the windshield on my 83 Scrambler, I have bought 3 used ones off of Ebay and one off of another Jeep sight, none have been ok to use. Rust, damage, etc. Is there a good new replacement frame available? I have heard the fiberglass is not the way to go. Any help or direction would be appreciated.
Thank you again.
mknherhappy is offline
post #2 of 6 Old 09-11-2011, 03:50 PM
SaskCJ7
1982 CJ7
I have no experience with replacement windshield frames, however I have heard that a 'glass frame will crack or even break from a tight-fitting soft-top.
The flame job on the front of my first Jeep would've been so much cooler had the flames not been real.
SaskCJ7 is offline
post #3 of 6 Old 09-11-2011, 04:39 PM
ejeeperguy
1982 CJ7
the steel ones you can order thru Quadratec,com or 4WD.com. I get most of my parts at these two catalogs. should run under 200. you will never get a used one that won't have rust rot of some damage. The glass seems always to be cracked too. save yourself the bs and go new.
ejeeperguy is offline
post #4 of 6 Old 09-11-2011, 05:46 PM
BlueRubiconrich
Get a used YJ frame do the upgrade!
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #5 of 6 Old 09-11-2011, 07:57 PM
scottymac62
1979 CJ7
They are pretty proud, but they sell a great product................http://www.jeepglass.com/7686.htm
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #6 of 6 Old 09-11-2011, 08:26 PM
BagusJeep
1981 CJ7
The steel one from Qadratech worked fine for me. They are rust traps, especially around the bottom edge, and the new ones are reasonable quality. You will struggle to find an original one in good nick and teh fibreglass ones are just not the same.
How long it will then last depends on whether you treat it internally, preferbly to a wax type treatment, and how you treat the areas behind the hinges and along that cowl seal.
Like all vehicles of the era thay may need some adjustment with a BFH before painting.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is online now
Replacement Windshield Abilene Jeep CJ Forum 2 08-08-2009 07:31 PM
replacement windshield 66 cj5 newjeepinidaho Jeep CJ Forum 2 04-18-2009 06:52 PM
Your Recommendations for Clutch Kit Replacement cfljeep Jeep CJ Forum 5 07-16-2008 07:49 PM
Replacement radiator for 258 - recommendations? obscurotron Jeep CJ Forum 16 06-02-2007 05:22 AM
windshield replacement cj 7 salematv Jeep CJ Forum 1 08-21-2004 10:39 PM
