Replacement shafts for late 86 Dana 44 - JeepForum.com
post #1 of 8 Old 08-22-2009, 10:01 AM Thread Starter
only in a jeep cj
Anyone have a source to find replacement axle shafts for the late 86 Dana 44 rear end? I have to look again at which one, but its bent at the flage area. They use to sell them years ago, now its just for the narrow track 44 for older CJs and the TJ units. My only other option is send them off to Moser for a custom set....but that is $$$$$ and I only need the one right now.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #2 of 8 Old 08-22-2009, 10:24 AM
trailridin4x4x4
1981 CJ7
Moser And Dutchman Make Chromoly Shafts For The W/t Dana44 As For Stock Replacements I Know Of No One That Makes Them And Have Only Seen Them Once On E-bay And Was Over A Year Ago.
81 Cj7, 4.0 Mpi, T5/dana300 Twinsticked, Wt Amc20 W/yukon Shafts, W/T Dana30 W/yukon Shafts, 35"mtr's
trailridin4x4x4 is offline
post #3 of 8 Old 08-22-2009, 05:44 PM
foggybottombob
You have found the major problem with using that axle.
foggybottombob is offline
post #4 of 8 Old 01-21-2010, 12:49 PM
ecardona10
I too have to replace 1 axle shaft on the 86 WT dana 44. Mine seems to be slightly bent, and when running at highway speeds, I start leaking oil out of the seal(and all into my drum brakes) i have replaced that seal and bearings twice, before I realized there was a slight wobble in the drivers side rear wheel. could an un-blanced tire or slightly bent rim be the culprit of a leaky seal instead of a bent shaft?
Also, did anyone find out who sells these?
Thanks,
Edwin C
ecardona10 is offline
post #5 of 8 Old 01-21-2010, 02:46 PM
domer1
1968 CJ7
Mine too
I too having the problem with my 86 CJ7 rear WT Dana 44. I have replaced the seals and still they leak on my disk brakes. I dont know what to do about this. Hate having to press off the bearings which in turn destroys it and replacing the seal. Getting expensive. And wrapping a rag around that area sucks. Heys its keeping the fluid off the rotars. Still wants to leak. How can you tell that the axle is bent? Has anyone tried the speedy seals to thicken the area where the seal meets the axle shaft? I need to try something.
domer1 is offline
post #6 of 8 Old 01-21-2010, 03:04 PM
domer1
1968 CJ7
Anyone know the exact bearing and seal part numbers for this axle shaft? Allways get the run around when at the parts house. I think for the seal it is National 9912S and the bearing is Timken Set10 or BCA A10.
domer1 is offline
post #7 of 8 Old 01-21-2010, 03:53 PM
ecardona10
look in the catalogues (Quadratech or 4wd)to verify that I'm right, but if I remember correctly the outer bearings and seals are the same as for a 97 to 06 TJ with a Dana 44. Somebody please verify this for me before buying the parts.
post #8 of 8 Old 01-22-2010, 04:30 AM
Ziptie2k2
I ordered my bearings and seals from Morris 4X4 in December. They work fine so far. Seal item # is 83503063 ($3.99 ea.), and bearing item # is 83503064 ($33.99). Here's the link for the entire D44 page. http://www.jeep4x4center.com/jeep-ax...ar-cj7-cj8.htm
1977 - CJ7.......1979 CJ7.......1981 - CJ8.......1986 CJ7 Cant get enough!
Originally Posted by 442Wrangler View Post
where do you believe you go when you die?
Originally Posted by sanchagrins View Post
you go in the ground, duh.....
Ziptie2k2 is offline
Late model replacement for a 304 oil dipstick tube chet44 Jeep CJ Forum 9 12-31-2009 04:53 AM
dana 60 axle shafts hard to turn after replacement mowjoecj Jeep CJ Forum 0 12-14-2009 04:56 PM
Dana 44 NT axle shafts 1980tallcj7 Jeep CJ Forum 1 08-10-2008 01:44 PM
Dana 30 axle shafts BigDumy Jeep CJ Forum 3 05-01-2006 10:05 AM
dana 30 axle shafts hot rod Jeep CJ Forum 11 07-31-2004 10:55 PM
