Replacement gauges with proper light coloring? - JeepForum.com
post #1 of 23 Old 01-24-2013, 11:58 AM Thread Starter
Cutlass327
Cutlass327's Avatar
1978 CJ5
Looks like I'll need a new oil gauge, the glass cracked and it is driving me nuts. I also want to fix the fact that my volt gauge is more yellow than the color it is supposed to be - looks like it is not an original gauge, it uses a different single wire light socket like an aftermarket gauge trio uses when compared to the oil gauge. I would love to find quality LED replacements and have them the proper color (Which is?? I am red/green colorblind) which I know this would solve the off-color issue, too.
Anyone find exact fit and color replacements?
Rick
Cutlass327 is offline
post #2 of 23 Old 01-28-2013, 02:07 AM Thread Starter
Cutlass327
Cutlass327's Avatar
1978 CJ5
Nobody?
Rick
post #3 of 23 Old 01-28-2013, 03:01 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Got me, I don't know.
We just bought a spectrophotometer here at work, maybe I can measure the wavelength.
John Strenk is online now
post #4 of 23 Old 01-28-2013, 03:08 AM
86cj74.2L
86cj74.2L's Avatar
Anything to play. Where I use to work it was always Christmas.
This is the mechanical oil pressure gauge in the 86.
The box said lighted. But it's not...........
86cj74.2L is offline
post #5 of 23 Old 01-28-2013, 04:04 AM
stgil
1982 CJ7
The OEM filament lights bulb gauge are not LASER... It'snt ONE wavelength... it is many...
Spetrophotometer will give you many and many wavelength... a spectrum of wavelength... hard(impossible) to find a perfect LED replacement bulb with this.
WHITE LED bulb has a "tight" spectrum (usually with UV too) than Filament Bulb ...
The best way is to buy RGB LED and fit the right spectrum... but...I don't think you find a RGB LED smaller enought for the oem brackets and it needs a controller...
Regards,
Gilles
FULL DANA 30 REBUILD->
CJ7 LAREDO REBUILD->http://www.jeepforum.com/forum/f8/82-cj7-laredo-diesel-restoration-1179198/
stgil is offline
post #6 of 23 Old 01-28-2013, 04:04 AM
stgil
1982 CJ7
Spetrophotometer will give you many and many wavelength... hard to find a perfect LED replacement bulb with this.
WHITE LED bulb has a "tight" spectrum (usually with UV too) than Filament Bulb...
The best way is to buy RGB LED and fit with his controller the right spectrum with it ... but...I don't think you find a RGB LED smaller enought to fit in the OEM brackets and it needs a controller...
Regards,
Gilles
stgil is offline
post #7 of 23 Old 01-28-2013, 04:45 AM
stgil
1982 CJ7
Here is a RGB LED with controller:
HERE
You can replace controller with the RIGHT amount of resistors and a (3 may be) voltage regulator ...
Regards,
Gilles
stgil is offline
post #8 of 23 Old 01-28-2013, 05:54 AM
John Strenk
1976 CJ5
On the OEM gauges, they usually have a filter over the light.
anyways our Spetrophotometer will give us a graph of the relative intensity of all the wavelengths from IR to UV and everything inbetween.
Something like this: This is for an incandescent light bulb
White LEDs look more like this:
An RGB LED would be interesting..
I'd just cut out the filter and put it in the new gauge. There is always Nail polish....
post #9 of 23 Old 01-28-2013, 06:13 AM
stgil
1982 CJ7
Nice result John!
That confirms,that WHITE LED has more UV than incandescent lights bulbs, and heated not a lot: 3 times less IR than bulbs with filaments
Regards,
Gilles
stgil is offline
post #10 of 23 Old 01-28-2013, 06:51 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Cutlass,
The factory dash light color is a light green on my '81.
The only OEM-style aftermarket gauge I've bought was a Crown tach. It has a non-colored light, which kinda irritates me since it doesn't match the rest of the dash.
Good luck,
Matt
Matt1981CJ7 is online now
post #11 of 23 Old 01-28-2013, 07:43 AM
timgr
1975 CJ6
Re the S-W gauge, they may call it lighted, but I recall you'll need to buy the lighting kit. IIRC the Jeep factory lighting will pop in to the S-W gauges, so that's a point in their favor. However, the Autometer gauges have a red needle, and look more like the original gauges. But you'll have to splice in their lighting to the existing harness - and they do not ground through the gauge shell, so you'll need to route a ground wire too.
You could try super-bright LEDs http://www.superbrightleds.com/ for a colored replacement bulb. That will give you some control of the bulb color. You can always adjust the intensity of LEDs down by adding a resistor in series - that would be another way to try and make the gauge lighting match.
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
post #12 of 23 Old 01-28-2013, 08:08 AM
Pathkiller
1974 CJ5
Autometer Traditional Chrome and Z-series come with both red and green bulb covers. The green appears to be very close to the original gauge color to my non-spectrophotometer calibrated eye.
Pathkiller is offline
post #13 of 23 Old 01-28-2013, 08:31 AM
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
I know this may sound tedious but here's my take..
The original Volt and Oil Pressure gauges were made by Faria Instruments.
Get yourself a set of old dead OEM gauges then get new Faria replacements, take bezels off and transfer the Jeep propietary faces to the new gauge, paint the needles flourescent orange and voila new gauges as good or better than original.
https://faria-instruments.com/store/index_standard.php
Or keep the search on and find NOS gauges like I did.
'85 CJ-7 Laredo currently under construction.
BlkCJ7Laredo is offline
post #14 of 23 Old 01-28-2013, 09:03 AM
Matt1981CJ7
1981 CJ7
Blk,
Thanks for that info.
Do you happen to know who made the original CJ tach and clock, and can a guy do the same to those?
Matt
post #15 of 23 Old 01-28-2013, 09:07 AM
BlkCJ7Laredo
Faria Instruments made the original tach. I don't believe they make that style gauge anymore however by the looks of the website that I provided the link above. Borg Instruments made the clocks. Here's a link to the current company information. I don't know if they'd be able to help you or not:
http://www.indak.com/company_profile/borg_indak.htm
