Replacement Fender Suggestions? - JeepForum.com
post #1 of 12 Old 09-19-2011, 01:32 PM Thread Starter
85CJ7denver
I am looking to replace the original fenders on my 1985 cj7. I'm new and dont see how to attach a pic..But...The sun has faded out the fenders into that nasty grey looking stuff that you see so often.
I have seen many options for replacement fenders but I am all ears if you have used a certain brand that you have been happy with. I dont plan on modifying the jeep into a rock crawler or anything, so I am looking to stay with more of a stock style fender. I do have a 5'' lift and 33's on it though, so something a little more aggressive may not look that bad at all.
Let me know what you've been happy with...Thanks,
85CJ7denver is offline
post #2 of 12 Old 09-19-2011, 01:42 PM
BrandonJames
1974 CJ5
are you talking about the fender flares? if so just take them off and paint them...
BrandonJames is offline
post #3 of 12 Old 09-19-2011, 01:54 PM Thread Starter
85CJ7denver
Im sorry...fender flares
What would you use, just a little spray paint?
post #4 of 12 Old 09-19-2011, 01:56 PM
BrandonJames
1974 CJ5
yea, Just get some duplicolor plastics paint from walmart or something, thats what I used.
post #5 of 12 Old 09-21-2011, 10:54 AM Thread Starter
85CJ7denver
quick question guys...I am about to go down the path of painting my existing fender flares, but wanted some advice...
Take the fenders off and paint them?
Mask the body and paint them while they are on?
I am sure a few of you have gone down the path of doing this both ways and have an opinion. Obviously, leaving them on may be the easiest, but I dont want it to look like &%$# either...
post #6 of 12 Old 09-21-2011, 11:46 AM
BrandonJames
1974 CJ5
I just took mine off, much easier, then you dont have to worry about overspray. They are just on there with like 4-5 bolts I beleive.
post #7 of 12 Old 09-21-2011, 01:51 PM
Btowntaz
1980 CJ7
If your fender flares have never been off, they might be a pain in the *** to get off. Check how many bolts and thier condition before making up your mind!
Also are the flares rubber or plastic? On my 80 CJ-7 the flares were rubber and cracked all to hell. If they are rubber, might want to think about just getting new ones, before they fall apart!
http://www.quadratec.com/products/22510_00_07.htm
My Jeep build:
Originally Posted by SaskCJ7 View Post
First off, whoever invented Torx bolts should be shot in the face, burned then pissed on.
Btowntaz is offline
post #8 of 12 Old 09-21-2011, 07:07 PM
robert1973
1977 CJ7
Krylon fusion is great for fender flares. its made for painting plastic.
ΜΟΛΩΝ ΛΑΒΕ
The Right is wrong and the Left is stupid
robert1973 is offline
post #9 of 12 Old 09-21-2011, 11:47 PM
Badshot
I used Mothers Back to Black polish. Took all the oxidation off and made them shiny black.
Badshot is offline
post #10 of 12 Old 09-30-2011, 01:43 PM Thread Starter
85CJ7denver
I ended up buying a pair of brand new rugged ridge replacement OEM style flares on ebay for $49...shipped it was around $60.
You would think pulling off the old fender flares and putting the new ones on would be simple, right? Not at all. About 6 hours later I am finally 95% done. I have a couple of bolt holes that arent lining up so I need to drill out the flare some to hopefully get the screws through and pull everything into place.
One thing I noticed on the new ones (rugged ridge brand) is that the back flares on both the driver and passenger side have sort of a bulge in them. almost exactly in the center of the flare on both sides there is a spot where it kind of kinks up and pokes out rather than being smooth all the way across. Anyone ever delt with this before? I am hoping to drive it and park it out in the sun for a bit this afternoon and left everything heat up on it and hopefully settle into place.
They look good, but never envisioned anything over 2 hours to get it all done...
post #11 of 12 Old 09-30-2011, 01:48 PM
WoodyHD
1983 CJ7
I'll tell you what also works. If you have access to MEK, an industrial solvent, it'll turn them as black as they were new. I rubbed mine down with the stuff and buffed out the streaks and they look great.
WoodyHD is offline
post #12 of 12 Old 11-10-2011, 11:16 AM
turbogus
1978 CJ5
How did this ultimately work out for you?
Some scheissekerl bumped into my fender flare on the right front and cracked it along the fender line. I like the style of the OEM and want another set. I wonder if there ARE good, better, best makers/sellers of these OEM flares out there?
Thanks for posting, and a lift of the lynch lid.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
Carb Replacement Suggestions Hank86 Jeep CJ Forum 7 08-09-2009 08:17 AM
Exhaust replacement suggestions! littleturner76 Jeep CJ Forum 13 06-11-2009 07:27 PM
Carb replacement suggestions....... BIG4D Jeep CJ Forum 8 04-23-2007 05:40 PM
replacement tranny suggestions oldhokie Jeep CJ Forum 13 03-23-2005 03:44 AM
Front Fender Replacement Futbolfan Jeep CJ Forum 4 02-09-2004 06:00 PM
