Hey Guys, the love of my life died a few weeks ago. I am hoping you can help me bring her back to life. Was wondering if there is someone who sells used or refurbished engines that will fit a 1978 CJ5. I'm going out of my mind with this nice weather and not being able to drive her. Any help you can give is appreciated.
Could I suggest you fill out your profile? You will get more accurate (but still wrong) guesses from the crowd on here but as they say, "An almost infinite number of monkeys hitting an almost infinite number of keyboards will eventually type a Shakespear play".
Plenty of engine builders out there, what have you got and where are you? What is your budget? can you wield a spanner?
HI, OK.. how did it die? could be something simple... who told you it was dead and need replaced? there are a lot of things that can go wrong causing the motor to die that are a simple fix or less costly that a replacement..
give us some words other than it died..
If you set on replacement just look for a shop to rebuild what you have or find one already done of the same size..
good luck
tim
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
