Replacement Dashpad Question - JeepForum.com
post #1 of 11 Old 01-30-2013, 11:04 AM Thread Starter
CousinCJ
1983 CJ7
I ordered a replacement dash from Amazon (I had some cash back to spend). Got it and the tab shaped part in the driver side was smushed in. Like it had been stored on its end. The cutout for the wiper motor doesn't give enough support to do that. So it looked mashed and the tab or wing on the end was crooked. Sent it back.
Second one came and it too is a little bit this way but not nearly as bad. I have been trying to warm it up in an attempt to shape it right. Don't want I send it back again as this one is passable.
It's omix brand and I know how that can be sometimes. Appears to be the only guys who make them.
Anybody had any experience with fixing this problem?
CousinCJ is offline
post #2 of 11 Old 01-30-2013, 11:07 AM Thread Starter
CousinCJ
1983 CJ7
This is how it came the first time and got sent back.
CousinCJ is offline
post #3 of 11 Old 01-30-2013, 11:14 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Cousins,
I just replaced mine. The whole wiper motor end of mine was warped, too, probably about an inch.
I placed mine over a heat register in the house, then sat a heavy tool box on it. I let it sit like that for about 2 days.
It didn't straighten out perfectly, but it did straighten enough to install it, with a little effort. Once I got it screwed down, it looks good.
Good luck,
Matt
Matt1981CJ7 is offline
post #4 of 11 Old 01-30-2013, 11:19 AM
PROJECT 23
No experience with this, but I do have an extra OEM dash pad if that one doesn't work out. The only issue is that it has a crack and a small chip. I'm sure with a little Bondo it could be repaired....
Just an option....
PROJECT 23 is offline
post #5 of 11 Old 01-30-2013, 11:33 AM Thread Starter
CousinCJ
1983 CJ7
I have one of those rolling clothes racks. Hung it from the end by the hole where the wiper motor is about a day ago. And put it under the heat vent from the ceiling. It seems to have moved just a bit. Next idea was to lay it in front of a space heater.
I guess I was just disappointed you spend that much and can't even get it in the shape its supposed to come.
CousinCJ is offline
post #6 of 11 Old 01-30-2013, 01:06 PM
hasselback
Just an option....
I've been trying to hunt down an OEM pad forever now. How much do want for it?
hasselback is offline
post #7 of 11 Old 01-30-2013, 01:34 PM
PROJECT 23
Check your PM
post #8 of 11 Old 01-30-2013, 02:00 PM
Renegade82
1982 CJ7
Try to clamp it to the correct shape, then try some heating and cooling cycles while it's clamped.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #9 of 11 Old 01-30-2013, 04:52 PM
Quailguy
Look around. I found one on eBay from a little company on the east coast. Perfect condition and $75 bucks cheaper. I'll find the name of the company in a bit.
Quailguy is offline
post #10 of 11 Old 01-30-2013, 04:59 PM
Matt1981CJ7
1981 CJ7
Was it CSE Offroad in NY?
Matt
post #11 of 11 Old 01-30-2013, 06:43 PM Thread Starter
CousinCJ
1983 CJ7
Matt
I got my Rock Hard Sport cage from them.
CousinCJ is offline
