replacement carb for 304 - JeepForum.com
post #1 of 6 Old 05-19-2003, 11:13 PM Thread Starter
daytoncj
what carbs are out there for my v8 304 motor? ive looked around alot and have failed to find anything besides oem carbs. does anyone make an off road carb for this motor? give me some opinions and list why you would go with that carb. thanks.
daytoncj is offline
post #2 of 6 Old 05-20-2003, 01:53 AM
Sandman74
I am running a 4brl Holley avenger 670cfm. Great power and pickup, ****ty mpg. Edelbrock makes several that will work. Try summitracing.com or 4wd.com but carry carbs for the 304, just a matter of figureing out what you want out of a carb.
sandman74
Youth and talent is no replacement for age and treachery.
Sandman74 is offline
post #3 of 6 Old 05-20-2003, 02:38 PM
Lightningdon
Lightningdon's Avatar
I've got the Edelbrock Performer series carb 600 cfm. Got mine from Summit online, reconditioned for $197. Sits on an Edelbrock performer intake. I'm very happy with it.
'97 TJ
'75 CJ5 304cid, t18 tranny w/granny low, model 20 T Case, DANA 44 rear, 30 front, 4" suspension lift, 33" tires, in need of more work!
"The only thing necessary for the triumph of evil, is for good men to do nothing." (Edmund Burke)
Lightningdon is offline
post #4 of 6 Old 05-20-2003, 05:21 PM
fuzz401
1978 CJ7
for a stock 304 i would not go over a 6oo holly or elde card you can always get an adapter for 2 bbl to 4 bbl to see if you like it then go with a manfold then i would go with an airgap intake
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #5 of 6 Old 05-21-2003, 07:20 PM
Lightningdon
Edelbrock has a 500cfm carb. Should be good for stock 304. I have headers, big duals, aftermarket intake, otherwise fairly stock internally. 600 cfm does well on this combo.
'97 TJ
post #6 of 6 Old 05-26-2003, 09:28 PM
qualityhardware
qualityhardware's Avatar
My '73 CJ5 has a 4bbl Holley 4160 600cfm carburetor sitting on an Edelbrock intake manifold. I just rebuilt the carb last week, finding a small gasket missing from the vacuum diaphragm. Runs much better. I kept stalling at stops or after applying the brakes rather robustly.
My understanding is that an Edlebrock or Holley 600cfm carb is a good match for an AMC 304 V8.
qualityhardware is offline
Carb Replacement Suggestions Hank86 Jeep CJ Forum 7 08-09-2009 09:17 AM
best replacement carb for 258 namredla Jeep CJ Forum 20 03-14-2009 09:22 PM
86 CJ Carb. replacement FloridaJeep Jeep CJ Forum 5 09-16-2008 09:10 PM
Carb replacement suggestions....... BIG4D Jeep CJ Forum 8 04-23-2007 06:40 PM
Need help with replacement carb for 258 1 bbl thepowertowin Jeep CJ Forum 9 06-14-2006 07:02 AM
