Replacement bushings for RC lift???? - JeepForum.com
post #1 of 5 Old 09-27-2011, 05:48 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
After about a year and a half of minimal use, the shackle bushings that came with my RC 4" lift are shot.
Obviously, now is the time to upgrade to poly.
After several conversations with RC's online customer service (who weren't much help at all) this is what I am told:
1) ONLY Rough Country's bushings can be used
2) Through RC, the bushings run about $30 per axle, for JUST THE SPRING EYE BUSHINGS!
This doesn't seem right to me.
Has anyone else with an RC lift come across another option for bushings?
Thanks in advance!
2X
2Xtreme is offline
post #2 of 5 Old 09-27-2011, 02:51 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
you must not have gotten a decent CSR. I allways deal with Josh at x111 or joey at x119.
When i did my 2.5 the first time around i did a complete set of daystars and fit just fine. KEpt the set that came with my 2.5 as spares.
actually used a pair of the spares when i had to swap a leaf out a few weekends ago on my 4" and fit just fine. Just pay attention to them.
fronts are thinner and the back eye has the wide shoulder bushing. rears have 2 that match up for width on the shackel and use the narrow shoulder ones for the front eye.
and if you mention jeepforum you usually get a 10% discount through rough country direct.
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #3 of 5 Old 09-28-2011, 11:07 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
So if I understand correctly, the Daystars should work?
But RC may discount 10%
2Xtreme is offline
post #4 of 5 Old 09-28-2011, 11:51 AM
Redmanchew
Redmanchew's Avatar
1982 CJ7
i did daystar when i first got my jeep 6 years ago because i needed a complete set body springs everything. i used them with my 2.5 RC lift because they were better and i had them. They worked fine.
post #5 of 5 Old 09-28-2011, 12:20 PM
Boodyrider
When you call, ask for Jeffery and mention JeepForum. You'll get excellent service.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
Daystar replacement bushings for RE iownaniroc Jeep CJ Forum 1 09-26-2011 12:16 PM
dana 30 difference, and ghetto shackle lift replacement ?s klayton Jeep CJ Forum 1 03-25-2011 09:49 PM
Daystar Body Lift Bushings for CJ Smitm16 Jeep CJ Forum 8 08-07-2009 12:15 AM
Lift kit bushings/ Body bushings, This is confusing me!! FLBOY Jeep CJ Forum 5 04-03-2009 09:13 AM
Replacement Lift Gate Struts BBOW Jeep CJ Forum 2 11-25-2008 06:35 AM
