Replace straps with gas tank? - JeepForum.com
post #1 of 6 Old 10-31-2002, 08:06 PM Thread Starter
Jami
1973 CJ6
I am wondering if a get a replacement tank of the same size if I will be able to reuse the straps that are on there now, or will I need to get new ones.Thanks
73 CJ-6 in the works
Jami is offline
post #2 of 6 Old 10-31-2002, 08:46 PM
Jeep Daddy
Jeep Daddy's Avatar
For the CJ or the TJ?
The CJ uses the skid plate to hold the tank up. It has one strap on it, for or five bolts in the rear and I believe 2 bolts up front. The skid plate is lined with rubber to reduce noise and friction.
I have no idea about the TJ
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #3 of 6 Old 10-31-2002, 08:58 PM Thread Starter
Jami
1973 CJ6
Sorry, yes it is for the CJ. I have seen a strap on both sides, I guess I figured there was two underneath the skid. So I could, pending the condition, reuse the one that is there right.
Thanks
Jami is offline
post #4 of 6 Old 11-01-2002, 01:15 AM
Jeep Daddy
Jeep Daddy's Avatar
You should be able to reuse the old strap and skid plate. The only reason I would think you couldn't is that it is damaged or rusted real bad.
post #5 of 6 Old 11-01-2002, 02:03 PM
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
I just got a new tank, skid plate and all three straps. The straps from quadratec aren't that expensive, so you might get new ones. I looked at my old ones and they were all beat up and unusable. You might luck out, but all in all it may be a better idea to go with new ones. The kit for a 76 CJ was like 49 bucks for all three straps. I also got the new sending unit as well. I went all new and together for the
tank
plate
sending unit
straps
was like $325 with the shipping. I don't know what your budget is, but I definitely agree with the motto of doing it once and doing it right. If it is in question, probably better to replace it.
certifiablejeep is offline
post #6 of 6 Old 11-04-2002, 11:18 AM Thread Starter
Jami
1973 CJ6
I agree with the motto, but my budget doesn't at this point. I already have a new sender and am getting the tank. I will see what kind if condition they are in and take it from there. Thanks
Jami is offline
Tank is full, fuel gauge reads Half tank!?! martyweir Jeep CJ Forum 10 09-25-2008 07:55 AM
Need to replace a stock 20 gallon gas tank abbysdaddy Jeep CJ Forum 9 09-07-2008 07:32 AM
Limiting Straps? bluwtrsurfr Jeep CJ Forum 3 04-07-2008 09:43 AM
door check straps bjf498 Jeep CJ Forum 4 10-29-2006 12:48 AM
Need to replace fuel tank... Key Jeep CJ Forum 6 09-23-2006 03:51 AM
