replace my distributor - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > replace my distributor
2001 - 2004 Jeep Grand Cherokee Power Window Regulator wit1990 - 1998 Jeep Cherokee Front Wheel Bearing & Hub AsEngo winches available at www.rockridge4wd.com! Free shipp
Unread 08-18-2004, 01:11 PM   #1
twmattox
Help,
I need to replace my distributor. Can anyone give me basic guidelines for this procedure???
AMC 150 motor
twmattox is offline   Reply With Quote
Unread 08-18-2004, 11:25 PM   #2
KGBnumber1
BASIC guidlines:
take the cap off the old distributor - make note of where the timing is. take of spark plug wires, and the wire harness going to the dist. unbolt it and pull it out, straight up.
put the new one in, in the same position the old one was in. make sure the timing is the same place as the old one was when you took it out. if not, pull it up and turn the top a little, then put it back down in. bolt it down tight, and wire it back up.
it is important you get the timing correct, and you put the plug wires back in the right place.
KGBnumber1 is offline   Reply With Quote
