Renegade Slotted Aluminum Wheels - Page 3 - JeepForum.com
post #31 of 48 Old 02-19-2009, 08:54 AM
JoonHoss
2011 JK Wrangler
Originally Posted by incynr8 View Post
with the center hole issue, I don't think there was or is any rim, that looks similar...that 'fits'.
well, I know that there are, I know quite a few people who have sets on there Jeeps that aren't the factory original 15x7's, most are the 15x8 or 15x10's... they were made, there just aren't a ton of them still floating around...
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #32 of 48 Old 02-19-2009, 09:14 AM
incynr8
1974 CJ5
Ones that look 'like' the D slots?
Maybe they are the OLD ansens?
incynr8 is offline
post #33 of 48 Old 02-19-2009, 09:44 AM
JoonHoss
2011 JK Wrangler
yep! aluminum D slots.
In fact, I just got off the phone with a buddy who has one set on his CJ5, and one on a CJ7. funny part is, I was telling him the story, and he said:
"yep, I know what you mean, I have a beautiful set in the garage right now, but I didn't measure the center hole before I bought them. they are 3.75, too!"
Hoss
JoonHoss is offline
post #34 of 48 Old 02-19-2009, 05:23 PM Thread Starter
starfire340
1983 CJ7
Hey 243, I assume the wheels on your 83 do not hit the calipers?
starfire340 is offline
post #35 of 48 Old 02-19-2009, 06:57 PM
243
1978 FSJ Cherokee
They bolted right on, but I will look and see how much clearance I have and post this weekend.
Dave's 78 Build
243 is offline
post #36 of 48 Old 02-19-2009, 08:55 PM
gladetop
1980 CJ7
We put a set on my fathers 1980 cj-5 and they fit great!
gladetop is offline
post #37 of 48 Old 02-20-2009, 07:44 AM Thread Starter
starfire340
1983 CJ7
gladetopjeep...does your dads 80 cj have front disc brakes?
post #38 of 48 Old 02-20-2009, 01:43 PM
JoonHoss
2011 JK Wrangler
Ripped this from jayhawkclint's build thread- http://www.jeepforum.com/forum/showthread.php?t=359375
post #241 (hopefully he doesn't mind)- but I thought it might help:
Originally Posted by jayhawkclint View Post
Thanks for the compliments.
Have done a few projects on the JEEP recently. Got a set of aftermarket slotted wheels. Would rather not tell what I did to get the wheels to shine as it falls into one of those "Kids don't try this at home" categories. Put on a set of 33x10.50 BFG MT. Had to install wheel spacers in the front to mount them over the discs. Once the tires were under the fenders, started looking at the trail damage on the rear. Decided to cover over with diamond plate for now. Not a big fan of diamond plate, but it does look better to my eye than a mangled rear quarter.
Hoss
JoonHoss is offline
post #39 of 48 Old 03-16-2009, 10:17 PM
gladetop
1980 CJ7
Yep, it has disc on the front...
gladetop is offline
post #40 of 48 Old 03-17-2009, 12:02 AM
Oily
Any good machine shop should be able to enlarge a hole, no ?
Oily is offline
post #41 of 48 Old 03-17-2009, 08:52 AM
JoonHoss
2011 JK Wrangler
I'll let you know, I'm taking one from another set to see how much $$$ to do just that.
Hoss
JoonHoss is offline
post #42 of 48 Old 03-17-2009, 09:23 AM
Oily
I had a 61 Ford Ranchero, four lug wheels. I had a 79 Celica Supra, four lug aluminum wheels. Same bolt pattern. The center opening on the Celica wheels was too small. I used an electric drill an a grinding stone and opened them up to fit. Then, had them balanced.
Too simple, .
Oily is offline
post #43 of 48 Old 03-27-2009, 02:11 PM
dave123
1975 CJ5
I have 5 rims 15 x 7 that look like the ones in the pictures on my 1975 CJ5 Renegade. Most of the Jeep is original, so there is a good chance they are original. They are in good, but not perfect shape. I have pics if anyone wants them, they can make an offer. I'm looking to get some wider rims so that I can put wider rubber on my Jeep. My rims currently have have BF Goodrich A/T's (31"). Would consider a trade for rims and tires.
Dave
dave123 is offline
post #44 of 48 Old 06-24-2013, 11:44 AM
CJKevin1978
I have aquired a set of these and looking for some lugs. I have heard WTH is that a couple of times when I show them the lugs that I have (only have 7). The lugs I have are tapered AND shanked. The shank is really thin walled. It seems that there is conflicting info regarding these wheels. If anyone is running with a set, can you describe the lugs?
Also, I have found that the centers of my steel wheels do not fit inside these wheels and they seem to fit tight against the axle hub. I am not crazy about the look of the back wheels without centers but, with these being so hard to find, I think it might be a mistake to have the hole opened up. So, what are the other "slotted" owners doing with centers on the rear.
BTW, if the question still remains on this old thread, these fit over my brake calipers without any issue on my 1984 CJ. If I had the lugs, I'd be running them now and trying my best to ignore the center issues.
CJKevin1978 is offline
post #45 of 48 Old 06-24-2013, 03:10 PM
JoonHoss
2011 JK Wrangler
Originally Posted by CJKevin1978 View Post
Also, I have found that the centers of my steel wheels do not fit inside these wheels and they seem to fit tight against the axle hub. I am not crazy about the look of the back wheels without centers but, with these being so hard to find, I think it might be a mistake to have the hole opened up. So, what are the other "slotted" owners doing with centers on the rear...
they probably aren't off a jeep then.
IIRC, you ned a center bore of 4.125" (or such), and my guess is that you have 3.75"
got any pics?
Hoss
JoonHoss is offline
Rehabilitating aluminum wheels gojeepin Jeep CJ Forum 9 04-12-2011 09:50 PM
Renegade Aluminum Wheels And Centers baystrucksalvag Jeep CJ Forum 4 01-26-2009 09:57 AM
Which Jeep Aluminum Wheels Will Fit CJ? poppaw-2 Jeep CJ Forum 8 05-14-2008 04:38 PM
Refinish aluminum wheels??? aero mech Jeep CJ Forum 3 09-06-2007 04:21 PM
Recomended Cleaner for Aluminum Wheels panzer948 Jeep CJ Forum 7 08-12-2005 06:49 PM
