removing tierod end from steering knuckle - Page 2 - JeepForum.com
post #16 of 20 Old 05-03-2010, 05:37 PM
way_of_life
1978 CJ7
is the end on the steering drag link or wtvr its called (from pitman arm to knuckle) the same as the tie rod ends?
as in-- should I buy 3 of those inserts? (one for each end of tie rod and one for drag link)
°lllllll°
way_of_life is offline
post #17 of 20 Old 05-03-2010, 05:53 PM
CJ8Ted
1985 CJ8
You could (I think) un-scrue the tie rod untill the ends come out. Jack on the axle so the wheels can toe out freely as you turn the tie rod. As for the drag link remove the pitman arm end first than you should be able to get it out of the stearing knuckle end. I cant beleve the springs are that shot but I cant see anything else incorrect.
Ted
1985 CJ8 on 33s W/ 4.56s
CJ8Ted is offline
post #18 of 20 Old 05-03-2010, 06:04 PM
CJ8Ted
1985 CJ8
If the springs are shot would'nt they get flat and give it more clearance? I think these things are very arched, I wonder if the pearch was changed, allthough it would be the wrong way,(less caster) IMO.
Ted
CJ8Ted is offline
post #19 of 20 Old 05-04-2010, 04:50 AM Thread Starter
CALOcruiser
CALOcruiser's Avatar
1978 CJ7
CJ8Ted, are you guys still talking about my jeep? I've determined that the springs are not that shot, it's the new arc without the flip-over mod causing the problem. the perch has not been changed. The caster actually seems okay, visually speaking and by the way it drove. Adding shims would help the clearance a little(as 80CJ suggested), but I don't think I need it for caster. I can't figure out what kind of lift kit is on the this thing. It's bare min to get the correct lift (springs and shocks only). The other hardware is all original, including the lock nuts that fell apart in my hand when I loosened the u-bolts, and the cracked spring plate.
The drag link would need the same modification as the tie rod.
CALOcruiser is offline
post #20 of 20 Old 05-04-2010, 05:56 AM
way_of_life
1978 CJ7
would that kit alter the structural integrity of the knuckle at those holes or do they not need to be drilled that much more than stock size?
°lllllll°
steering knuckle swap edub78 Jeep CJ Forum 3 04-05-2010 02:54 PM
Steering Knuckle removal problem 2002fordgt Jeep CJ Forum 5 06-03-2009 11:38 PM
How do you pack a steering knuckle with grease? part.changer Jeep CJ Forum 12 09-03-2007 05:47 PM
Steering knuckle ball stud Indy Jeep CJ Forum 8 12-08-2006 03:53 PM
Removing ball joints for knuckle swap Blthomas Jeep CJ Forum 8 06-28-2006 02:14 PM
