removing stuck front brake drums? - JeepForum.com
post #1 of 13 Old 03-29-2013, 12:10 PM Thread Starter
tomass
1965 CJ5
I am working on rebuilding the entire brake system on my 65 cj5. The back braked went fine but moving on to the front, I can't get the drums off. I have tried soaking with pb blaster and hitting with a hammer, heating up with a torch and hitting with hammer and have sparingly used a sledge hammer. but so far no luck. any suggestions?
tomass is offline
post #2 of 13 Old 03-29-2013, 12:47 PM
Caish
1987 XJ Cherokee
The drums my be heavily grooved.
The shoes are holding the drum on.
So back off the adjuster through the little
slot with a brake spoon.
If that doesn't work, go to the back side
and grind the head of the brake nails off,
this will allow the brakes to pivot and you should
be able to pry the drum off.
Join us on Jeeperz Creeperz on Google+
Facebook: Arkansas Jeeps
Caish is offline
post #3 of 13 Old 03-29-2013, 12:48 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
you have obviously let all the pressure off your brakelines? I've never seen a hub that wouldn't come off when hit on the sides with a rubber mallet, working your way all the way around it a few times.. pulling it at the same time, little by little it should slip off.. you don't have locking hubs or something in the hub holding it on do you?
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #4 of 13 Old 03-29-2013, 01:12 PM Thread Starter
tomass
1965 CJ5
shoe groove may be the problem. I have looked and the locking hub is not holding it on. Here is a pic of it. I am going t go out after lunch and try adjusting the shoe pivot.
tomass is offline
post #5 of 13 Old 03-29-2013, 01:27 PM
John Strenk
John Strenk's Avatar
1976 CJ5
not sure if it goes back that far but sometimes they had some flat head allen screws holding the drum on to the hub.
I see one suspicious spot right about the 1:00 position in you picture.
Clean all the paint and grime off that spot.
John Strenk is offline
post #6 of 13 Old 03-29-2013, 03:58 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
seems to me you have to remove the locking hubs to get to the brake drums too.. I was going to do mine and stopped at that point..
frhrwa is offline
post #7 of 13 Old 03-29-2013, 08:42 PM
tjeep1
1978 CJ7
the drums dont come off without removing the hub assembly i do believe
tjeep1 is offline
post #8 of 13 Old 03-29-2013, 08:50 PM
Caish
1987 XJ Cherokee
Looking at the picture again,
I think they are right, those are inboard drums, ie come off with hub.
If you have a parts source I would want to change that over,
just because you can then use the same drums front and rear.
Caish is offline
post #9 of 13 Old 03-29-2013, 09:38 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
The drums are swagged to the lug bolts. This is a common occurrence on many early vehicles. This is done at the plant to keep the drum on the hub during assembly. Later models used a small Phillips screw to accomplish the same thing (model 20 rear drums).
You will have to remove the hub assembly to get to your brakes. If you need to separate the two, the best way is to use a special cutting tool that removes the swag. You can sometimes drive the lug bolt out, but many times you can damage the drum doing this.
jeepdaddy2000 is offline
post #10 of 13 Old 03-30-2013, 08:45 AM Thread Starter
tomass
1965 CJ5
If I remove the hub, then take the drum off will I be able to just put a replacement drum on. Or are there further modifications that will need to be done for a stock drum to fit on there.
tomass is offline
post #11 of 13 Old 03-30-2013, 11:09 AM
Noplainsdrifter
1974 CJ5
What is "swagged"? Never heard that term.
If your drums are loose but will not come completely off, then it's usually your brakes keeping them on and you'll have to back them off. But it sounds as is something else is holding them snug, either they are screwed to the bub or are inboard hubs.
It's a Jeep Thing, Chrysler Doesn't Understand!
Noplainsdrifter is offline
post #12 of 13 Old 03-30-2013, 12:11 PM
brian613
1977 CJ5
my 77 had the same setup on the front. you have to remove the hubs and outer wheel bearing to get the drums off there is no other way around it.
unless your wanting to stay stock i would recommend changing to disk breaks at this time since you have to pull it all apart anyway drum brakes suck.
77 cj5 304 v8 np435 twin sticked dana 20 transfer scout dana 44's with 4.88 gears
brian613 is offline
post #13 of 13 Old 03-30-2013, 01:30 PM
jeepdaddy2000
1971 CJ5
Swagging is when the studs use an elongated shoulder. The drum is placed on the hub and the shoulder is flattened over the drum hole, effectively attaching the drum to the hub. This was a common assembly procedure and was used by just about all the vehicle manufactures at one time or another.
Removing the swag entails using a circular cutter with four sharp bits. This is chucked up in a drill press, the hollow portion going over the stud, and the cutters shaving the swag off when pressed down, allowing the drum to be removed from the hub.
brakes , drum , tips
