Quantcast Removing Renegade decals and stripes - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Removing Renegade decals and stripes
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 02-24-2004, 12:14 PM   #1
rcsutton
Does anyone have an easy way to remove the Renegade decals and stripes. I am planning to paint so the artwork has to go, but I've got to be careful as not to damage the paint underneath. Sanding is out. The best way is the tedious task of razor blade, it may take me months. Any ideas??????????
1980 CJ 5. Hummer Yellow. SS dash, Rhino Lining 258 23 Gal gas tank Rock bumper Fnt & R. 8000# Ramsey Patriot Winch. Painless wiring. 411 gears OX rear Aussie front, dual batteries,Optima Red top, Firestone Destination M/T 33X 12.50 Sylvania Silver Star Head Lights, Rancho 9000, Superlift, Weber, KC off road lights, Cobra CB, DUI ignition etc $$$$.
rcsutton is offline   Reply With Quote
Old 02-24-2004, 12:54 PM   #2
xxxflhrci
3 good ways:
1.) Use a heat gun.
2.) Get some 3M Decal Remover from a place that sells auto painting supplies.
3.) Get a "decal eraser". It is a rubber wheel that attaches to a drill or buffer and spins the decal off. It won't damage the paint. You can also get it at a auto paint store.
xxxflhrci is offline   Reply With Quote
Old 02-24-2004, 04:27 PM   #3
Hale
im just curious, but if you are painting it, why do you care if the paint under the stickers gets damaged?
Hale is offline   Reply With Quote
Old 02-24-2004, 07:36 PM   #4
rcsutton
Originally Posted by xxxflhrci
3 good ways:
1.) Use a heat gun.
My neighbor runs a body shop and he's helping me and he says you don't want to damage the paint underneath it will be something else to fix. Tonight he brought over the exact three items mentioned above. I'll let you know.
Thanks
Old 02-24-2004, 08:24 PM   #5
Hale
I still don't get how damaging the paint underneath the decals could hurt anything if you are repainting the whole jeep? but I guess if he runs a paint shop you might as well listen to him.
Old 02-25-2004, 12:34 AM   #6
79cj360
if you have a nice clean surface to paint on, scratching and chipping it tying to remove the decal will mess up the final product. there will be dimples and such from where the paint was chipped. now if he sands the dimples etc ect.. out, it leaves waves int he paint over top because you will never sand it smooth again.
or if he allready has these such as waves or others, why add to them.
john
79 cj7
70 amx 360
turbo 350
12 inch lift
39.5's
np 208
re quick disconnects
rancho shocks
cutom driveshafts
snorkel
14 bolt rear
international dana 70 front w/closed knuckles
" damn modification bug bit me hard, so im bittin back!!"
"Go mud or go home"
79cj360 is offline   Reply With Quote
Old 02-25-2004, 07:55 PM   #7
rcsutton
Nice explanation, I'm not sure of all of the details but I'm following his directions. Lot of work taking off the decals. So far I've only tried the 3-m remover. Do you think the heat gun or rubber wheel will be easier?
Old 02-27-2004, 02:04 PM   #8
Stouttrout
I use to have a business that did alot of custom work for car and truck dealers. One of the things we did was removing and installing decals. We always used a heat gun. You have to be very carfull not to burn the paint. As soon as the decal begins to bubble you can pull it off. When you get the whole decal off there will be some sticky residue left over. You can use a product called "Goof Off" to remove the residue. the 3m will probably work also. Oh yeah, Goof Off is sold at Home Depot
Good luck
Let us know what you find is the easiest way.
Stouttrout is offline   Reply With Quote
Glock Forum
