Quantcast Removing Renegade Decals - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Removing Renegade Decals
Old 12-14-2006, 07:38 PM   #1
BeesJeep
BeesJeep's Avatar
1981 CJ7
I am currently restoring a 1981 CJ7 Renegade. It has the original paint with the decals. I am having a hard time getting the decals off. What is the easiest way to get them off? I have tried paint remover and sandpaper. Is there any other way? Any help would be appreciated.
BeesJeep is offline   Reply With Quote
Old 12-14-2006, 07:52 PM   #2
cook
heat gun? What I ended up doing to remove the ones on my jeep was to get a exacto knife set and use the wide blade it's about a 1/2 wide. you can get under the decal just above the paint just go slow. once you start you will know what I mean. You get pretty good at it after a while. then all thats left is a small layer of glue. I used an orbital sander to remove the glus. I take it you are going to repaint? hope this helped.
cook is offline   Reply With Quote
Old 12-14-2006, 08:00 PM   #3
BeesJeep
BeesJeep's Avatar
1981 CJ7
Yea, I plan to repaint, it is currently the origianl light blue. I have not decided what color I am going with. Thanks for the info!
Old 12-14-2006, 08:05 PM   #4
Shameless Elmer
1983 CJ5
Use one of these. It's what they're made for. I used it on my restoration and couldn't believe how well it worked. It removed the decal and glue, and didn't harm the paint at all.
Do a Google search for Astro Pneumatic Eraser Pad.
Shameless Elmer is offline   Reply With Quote
Old 12-18-2006, 11:45 AM   #5
JoonHoss
1968 C101
ELMER is right on
we have to remove our old fleet decals everytime we surplus a rig- it is all but impossible, unless you use a decal eraser.
they also sell them in thin type pads, which you use in multiples in a die grinder or air-drill.
Hoss
It's hard to say no to yoo-hoo, the name literally beckons...
Don't mind me, I'm just another FNG around here...
JoonHoss is offline   Reply With Quote
Old 12-25-2006, 11:51 AM   #6
Woodyhfd
Eastwood sells something similar for removing decals.
Woodyhfd is offline   Reply With Quote
Glock Forum
