Removing heater blower motor? - JeepForum.com
post #1 of 14 Old 03-21-2008, 12:08 PM Thread Starter
mmerlina
Image Glassworks, Inc.
mmerlina's Avatar
Hey everyone, I don't remember exactly what it looks like under there, but I remember not knowing how to get the blower motor out of the vehicle. Is it behind the heater box?
When I upgraded to a mojave, I actually cut the heater box away because 1) I am impatient and a maniac at times and 2) if I remember correctly it was bolted from the firewall forward into the cab?
How do I get that motor out without destroying something?
Thanks!
Mike
1986 Jeep CJ7 (
Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work
mmerlina is offline
post #2 of 14 Old 03-21-2008, 12:11 PM
Mike Romain
There are 4 nuts on the engine side of the firewall you have to remove. The first one is dead center behind the valve cover.
Mike
Mike Romain is offline
post #3 of 14 Old 03-21-2008, 01:25 PM Thread Starter
mmerlina
mmerlina's Avatar
Bah, I hate that damn valve cover! ;p
Mike
1986 Jeep CJ7 (
mmerlina is offline
post #4 of 14 Old 03-21-2008, 02:34 PM
Mike Romain
You are going to hate it worse if you bump it when trying to get that nut off.... I used a box end wrench on it if I remember right.
Mike
post #5 of 14 Old 03-21-2008, 02:35 PM
bigjoe
1977 CJ7
Factory blower fan is bolted to back of heater box. You have to remove heater box to get at the fan.
bigjoe is offline
post #6 of 14 Old 03-21-2008, 05:58 PM Thread Starter
mmerlina
mmerlina's Avatar
I figured as much, how do you "properly" get the box out? Like I say I cut huge chunks of mine off to fit the mojave in there. Wasn't my first choice as an approach but patience wore thin I guess.. was a while back.
Mike
1986 Jeep CJ7 (
mmerlina is offline
post #7 of 14 Old 03-21-2008, 06:04 PM
Bard
Mike, PM me your email and I will send you a nice little .pdf
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #8 of 14 Old 03-25-2008, 06:23 AM
Oily
Bard, will you send it to me also ? Thanks.
I have all the firewall nuts removed and the heater core/motor case seems loose but is retained to the upper section, the fresh air/defrost duct work. I can not seem to find where to unmount that box. It does not seem to want to separate from the heater core box.
Oily is offline
post #9 of 14 Old 03-25-2008, 11:46 AM
Oily
The fresh air box is held in by four phillips screws under the fresh air intake grill.
Oily is offline
post #10 of 14 Old 03-25-2008, 12:09 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Yeah, I found that the hard way. I pulled the grill off and still couldnt find any screw. Mine were buried in some type of sealer the PO used to seal the duct. Or maybe it was the factory, it's hard to tell sometimes.
John Strenk is offline
post #11 of 14 Old 03-25-2008, 12:14 PM
hdroadkingc
If you need a heater box PM me. I have a used one I need to get rid of.
hdroadkingc is offline
post #12 of 14 Old 03-26-2008, 06:53 AM
Oily
Notes of interest. It has been mentioned here that the hole in the new motor housing is a drain and also it has been mentioned that it is for cooling. The story I get is that it is for cooling and that it is an intake port. An ell shaped hose is supposed to come out of the airflow duct work and into the housing. Just covering the hole may not be a good idea from the lifetime span perspective. Also, the common perception seems to be to use a blower motor from an 83 Blazer/Pick Up with A/C. The shaft is too long on the A/C model. You will need the non A/C blower motor.
Other questions. What has everybody been using to fabricate a new weather stripping pad as fond on the back of the CJ heater motor housing? I was looking for sheet material but could only find rolls of weather stripping. I have thought about carpet padding and even styrofoam.
Also, what have any done for a new seal between the heater box and the fresh air box? I would hate to have to order and wait for one.
Oily is offline
post #13 of 14 Old 03-26-2008, 07:19 AM
Redmanchew
Redmanchew's Avatar
1982 CJ7
Oily,
Just a though on the "gasket", how about sheet rubber. maybe something cloth impregnated that you can cut and punch holes in.
Keep us updated...this was my 2nd winter i "forgot" to do my blower motor upgrade.....
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #14 of 14 Old 03-26-2008, 08:57 AM
Oily
Originally Posted by Redmanchew View Post
Oily,
I found some at a local (not chain) hardware store. I would need at least six thicknesses at $2.19 a piece. I can get it in thicker batches at work for free but would still need multi layers.
I just got back from a carpet store. They had piles of leftover/used stuff. It comes in different grades. Some you can blow through and some plastic backed. I think it is the solution and will even work to seal the two units.
Oily is offline
Heater Blower motor upgrade napoleoneight Jeep CJ Forum 84 01-10-2015 04:12 PM
Chevy Heater Blower Motor MuddyMules Jeep CJ Forum 62 12-30-2012 02:26 PM
Heater blower motor dustbag Jeep CJ Forum 15 10-17-2009 07:11 AM
Did heater core, and blower motor upgrade, no fan now. Blthomas Jeep CJ Forum 13 02-13-2009 03:00 AM
Heater Blower ? Which One?? JERSEYJOE Jeep CJ Forum 9 07-09-2004 08:57 AM
