removing diamond plating - rivets - JeepForum.com
post #1 of 6 Old 10-22-2009, 09:33 PM Thread Starter
TophCasey
TophCasey's Avatar
So I bought a CJ7 and it is red with silver diamond plating...
... that's ok but i want to repair some body pieces but there is diamond plating in the way. I dont think i really need it on there cause its mainly going to be used to drive around to climbing spots and just kick around in on a few trails to do research (ecology student). So i had a few questions:
1. Wont the diamond plating help cause more rust?
2. What's the best way to get them off, they are riveted on there.
3. Is it worth it to take them off to repair rust or are the enough support?
Here's pictures:
http://i60.photobucket.com/albums/h2...J/IMG_0155.jpg
http://i60.photobucket.com/albums/h2...J/IMG_0154.jpg
This is it now:
http://i60.photobucket.com/albums/h2...J/P8080001.jpg
This is how i would like it to look:
http://i60.photobucket.com/albums/h2...91vZWU74az.jpg
Thanks
2004 WJ freedom edition - DD
Throttle body spacer, K&N air filter, rusty's intake system, 2" spacer, 31"s, and all kinds of Thule crap!
work in progress!
TophCasey is offline
post #2 of 6 Old 10-22-2009, 09:44 PM
dangjeep
The rivets are easy to remove, just drill the heads off the rivets by using a bit smaller than the head. Hold the back side of the rivet with a pair of vise grips, to keep them from spinning. Don't plunge through if you plan on using the same holes again for reattaching later.
dang
84 CJ7-258-T5-D300-4.10 gears 33" tires Nutter Bypassed Team Rushed
dangjeep is offline
post #3 of 6 Old 10-22-2009, 09:50 PM
daltonw
1981 CJ7
they'll only cause more rust if water and dirt and what not can get behind them and get trapped there. If they are tight against the side you shouldn't have any problems. also i've noticed that people try to cover rust up with those pieces instead of fixing it..
daltonw is offline
post #4 of 6 Old 10-23-2009, 08:18 AM
CSP
It doesn't matter how tight they are against the body panels or what sealant you use, dirt and water will get behind them and get trapped.
CSP is offline
post #5 of 6 Old 10-23-2009, 09:37 AM
twoleos617
TophCasey,
I would LOVE to have those pieces and would certainly pay for shipping and may be a little more for your time, when you get them off.
Let me know what you think. email or PM me with your thoughts.
If you have any more pics/links you could send me, that would be great!
Mike
Torque is the measure of force that gets the cap off your beer.
Mike D.
twoleos617 is offline
post #6 of 6 Old 10-23-2009, 09:41 AM
BriansCJ
1994 XJ Cherokee
Here's pictures:
If anyone around in this area wants them (sides and rear corner plates) you can come get them for free if you take them off yourself.
This is it now:
Thanks
Click free
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
Custom Chrome Plating Jiffy Jeep CJ Forum 0 03-07-2009 06:43 PM
Continuing brake problems on 76CJ7... removing bleeders, removing lines??? part.changer Jeep CJ Forum 3 04-19-2007 08:37 PM
Removing Rivets gtrpup2 Jeep CJ Forum 6 11-15-2006 09:07 AM
VIN Rivets? Mogman Jeep CJ Forum 13 02-22-2004 09:39 PM
Diamond plating - rear corners diggs Jeep CJ Forum 8 08-15-2003 08:25 AM
