Removing Dash Knobs - Help - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Removing Dash Knobs - Help
Yukon Zip Lockers FREE AIR COMPRESSOR AND ROCKRIDGE REBATEFree arb compressor with puchase of arb locker!!! Limited Nitro Gear Packages Now Available at Rockridge 4wd
Unread 02-07-2012, 03:13 PM   #1
tamu83cj
1983 CJ7
How do I remove the knobs off my dash pulls and switches? For the lights, HVAC, vents, fans, ect.
Thanks,
tamu83cj is offline   Reply With Quote Quick reply to this message
Unread 02-07-2012, 03:14 PM   #2
Outnumbered
Thanks,
They are not supposed to come off. You pull the whole cable assembly thru the dash. You can break them off to install the billet knobs though. But it is a one-way deal, no turning back
1985 CJ7, 258, TF999, D300, D30, AMC20, 4.5" lift, 33" BFG's
Outnumbered is offline   Reply With Quote Quick reply to this message
Unread 02-07-2012, 03:45 PM   #3
Balvar24
1979 CJ7
They don't just fall off while your driving down the road?
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline   Reply With Quote Quick reply to this message
Unread 02-07-2012, 03:55 PM   #4
Outnumbered
I thought it was just me so I did not mention that option
Unread 02-07-2012, 04:11 PM   #5
tamu83cj
1983 CJ7
Outnumbered, how do I replace the chrome spacers behind the nobs if I can't take them off?
Unread 02-07-2012, 04:11 PM   #6
keith460
Jeep. There's Only One
keith460's Avatar
Only the Light, Wiper and Fan switch have knobs that come off, all the rest must be pulled as a unit with the cable disconnected at the HVAC unit and then pulled out from the dash panel. You need to depress the sides of the plastic that is just behind the dash panel and pull while keeping the sides pushed in.
To get the Headlight switch off, you will need to depress a small button on the back and side of the Headlight switch as shown.
Wiper and Fan switch knobs have a small metal tang to depress while pulling it off at the same time.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote Quick reply to this message
Unread 02-07-2012, 04:20 PM   #7
Outnumbered
That is funny, I was just going to link 460's thread...
http://www.jeepforum.com/forum/f8/cj...15/index3.html
Unread 02-07-2012, 04:21 PM   #8
keith460
keith460's Avatar
Use a suitable tool like snap ring pliers to unscrew the spanner nut so you can remove the escutcheon piece.
The chrome escutcheon pieces are not removable from the pull cables.
1984 CJ-7 Renegade
Unread 02-07-2012, 04:35 PM   #9
John87
if you want to remove the knobs from the heater cables, you need to cut them to loosen its grip.
-John
°llllll° 1985 CJ-7
[url]www.jeepforum.com/forum/f8/85-cj-7-frame-resto-1311807/[/url]
John87 is offline   Reply With Quote Quick reply to this message
Unread 02-07-2012, 04:55 PM   #10
keith460
keith460's Avatar
Not so. An easier way is to pull out the knobs as far as they will go and then use a propane torch to heat the rod just behind the knob but not to close. Once the rod heats up enough, it will soften the the plastic inside the knob and you will be able to pull it off with ease.
That's how they are installed also.
1984 CJ-7 Renegade
Unread 02-07-2012, 05:01 PM   #11
Jon In Tucson
Jesus Is Lord!
Jon In Tucson's Avatar
1983 CJ5
Unless... they came apart on you and you repaired them with epoxy. Then they will stink as you heat up the at steel rod. Long story... God bless.
Jon In Tucson
Jeremiah 17:7 "But blessed is the man who trusts in the Lord, whose confidence in Him."
"The secret to a Jeep, especially a CJ, is you can't
panic." - Mike
"I may not be a smart man, Jenny, but I do know grounds."
Jon In Tucson is offline   Reply With Quote Quick reply to this message
Unread 02-07-2012, 05:17 PM   #12
Billy
Everyone [B]IS[/B] out to get you, if you just believe in yourself and try hard enough!
[COLOR="DeepSkyBlue"][B]Twitter[/B][/COLOR] @dutchoven86
Billy is offline   Reply With Quote Quick reply to this message
Unread 02-10-2012, 09:02 AM   #13
tamu83cj
1983 CJ7
Got them off with the propane torch idea.
Unread 09-02-2012, 01:36 PM   #14
ggraham
1984 CJ8
Keith - thanks for this. I would have never figured this out.
ggraham is offline   Reply With Quote Quick reply to this message
Unread 11-13-2013, 12:34 PM   #15
pyrexx
Dash knob removal
I was very frustrated trying to get the dash knobs off of my Jeep. I finally decided to go to the forum and see what you guys had to say. the torch method works like a champion. it took me 2 minutes to take the three knobs off of the dash. Now I can put my stainless steel knobs on, all of them. Thanks guys.
pyrexx is offline   Reply With Quote Quick reply to this message
