Removing ball joints for knuckle swap - JeepForum.com
post #1 of 9 Old 06-28-2006, 10:30 AM Thread Starter
Blthomas
Blthomas's Avatar
1979 CJ7
Do I need a BJ press, or can I use one of them fork things and a BFH they have at one of the stores?
I got the old D44 stripped down to the knuckles and need to pull them to put on the flattops from the Chevy axle.
Also, doing a hodgepodge of parts.
Waggy 44, Chevy flatops and spindles, and outers. To make everything fit with the Ford rotors and hubs, do I need to get anything machined?
Thanks,
Blair
79' CJ7 - 4" lift, 33's
81' CJ8 bone stock
80' Chief "S" 6" lift, 33's
Blthomas is offline
post #2 of 9 Old 06-28-2006, 10:40 AM
famicom21
famicom21's Avatar
Rent a fork thingy from auto zone for free, then use that to pry the steering knuckle off of the axle end. Then use a bench vise and a big *** hammer, along with a propane torch and some free-all, to remove the ball joints from the steering knuckle.
Yellow 86 CJ-7 Red 70 CJ-5
"Out on the road, out 'neath the stars, Feelin' the breeze, passin the cars."
famicom21 is offline
post #3 of 9 Old 06-28-2006, 11:39 AM
dave_dj1
an air hammer works best!
dave_dj1 is offline
post #4 of 9 Old 06-28-2006, 11:46 AM
junglejeep
Ball Joints
At this point I would buy new ball joints since you've got the axle torn down this far. Take your Chevy Flat tops to smoewhere like Napa and they can press them in for you.
They're not real expensive and you'll save time over replaceing old ball joints 6 months down the road when the old ones wear out.
I want a CJ-6 with a hardtop.
junglejeep is offline
post #5 of 9 Old 06-28-2006, 11:50 AM Thread Starter
Blthomas
Blthomas's Avatar
1979 CJ7
Thanks for the replys. I plan on replacing them for sure, and I don't need these knuckles for anything anyhow.
If I can get them off the axle, then I'll be set.
Couldn't I just use the nuts to draw them up into the knuckle? Instead of getting them pressed?
81' CJ8 bone stock
Blthomas is offline
post #6 of 9 Old 06-28-2006, 01:03 PM
jeepskate
You should be able to knock the knuckles off via a BFH on the upper ball joints (remove the nut on the lower joint, loosen the upper nut until it's flush with the top of the stud). You will need a press to put the new ball joints in the 'new' knuckles...just take 'em to NAPA or wherever and have them press them in or rent/buy a ball joint/u-joint service kit (should be able to buy for around $50 or so) and press them in yourself.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #7 of 9 Old 06-28-2006, 01:56 PM
rustyCJ
wow, you need to do a lot more research
only reason to go flat top is if you intend on going hysteer, did you machine the top of the knuckles?
here is some good info including how to remove/install D44 knuckles/ball joints;
http://77cj.littlekeylime.com/flatop_knucles.html
http://77cj.littlekeylime.com/Mr.N44.htm
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #8 of 9 Old 06-28-2006, 02:07 PM Thread Starter
Blthomas
Blthomas's Avatar
1979 CJ7
Did a bunch of research. Just never taken a axle apart, maybe the questions reflect a newb build?
I have both sites bookmarked from previous trolling of info, thanks.
I'm going high steer, I was SOA on the stock CJ axles. I bent the piss out of my draglink and tierod, so when swapping axles, seemed appropriate to do high steer while down.
No I haven't machined the knuckles yet, they are still attached to the Chevy axle I'm robbing them from.
I'm just trying to get the Waggy44 stripped completely, then I can start putting it all back together.
Thanks for the heads up, I have a folder in my favorites with close to 100 links saved, the keylime site is a good one. Just hard to remember what is what when you've read it all and never done it yourself.
This is a good one for some of the other details:
http://www.jeepgod.net/d44625.html
I'll get them pressed over at Napa,
Thanks
Blair
81' CJ8 bone stock
Blthomas is offline
post #9 of 9 Old 06-28-2006, 02:14 PM
jeepskate
You need to get the knuckles machined *before* you have the ball joints pressed into them.
D30 Ball Joints & U-Joints. Any Write-ups? DT5150 Jeep CJ Forum 7 07-02-2008 06:44 AM
Dust Covers Ball Joints U-Joints 6 bolt Hubs anwallac Jeep CJ Forum 5 05-16-2007 11:08 AM
Dana 30 Steering Knuckle ball joint style kappa505 Jeep CJ Forum 0 12-21-2006 09:28 PM
Steering knuckle ball stud Indy Jeep CJ Forum 8 12-08-2006 03:53 PM
ball joint shims or adj ball joints? jm708 Jeep CJ Forum 9 10-26-2005 09:45 AM
