Removing axles from D44 with Powr Lok - JeepForum.com
post #1 of 6 Old 06-30-2013, 11:36 AM Thread Starter
PaulS
1949 CJ3A
I've removed the axle shafts from my D41, and it was a matter of just removing the six bolts on the end flange, and everything (shaft, bearing/race, grease retainer, etc.) just slid right out.
But now I'm trying to do the same on my D44 with Powr Lok, and the shaft isn't coming out. Is there something that has to be done in the differential to release the shaft, or do I just need to pull harder?
Thanks,
-Paul
PaulS is offline
post #2 of 6 Old 06-30-2013, 12:09 PM
LumpyGrits
Make sure there is not a "C" clip hold'n the axle to the carrier.
LG
LumpyGrits is offline
post #3 of 6 Old 06-30-2013, 12:53 PM
jp360cj
1977 CJ7
Put the brake drum on backwards, evenly thread a few lug nuts on and use the drum like a slide hammer
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #4 of 6 Old 06-30-2013, 07:03 PM Thread Starter
PaulS
1949 CJ3A
Would a clip like that be easily visible? Where should I look? I can't see anything...
The brake drum as a slide hammer didn't do anything, either.
-Paul
PaulS is offline
post #5 of 6 Old 06-30-2013, 09:02 PM
CSP
There aren't C-clips on the Dana 44, regardless of what the carrier is. Turn a brake drum around, slide it onto the lug and attach a few lugs loosely. Use the drum like a slide hammer.
CSP is offline
post #6 of 6 Old 06-30-2013, 09:10 PM
titomars
1981 CJ7
-Paul
You will have to rent or borrow an axle shaft puller. It's a big 20 lb slide hammer with a bolt on flange. Are you sure all of the axle shaft retainer nuts off? There could be up to six of them. They are behind the axle flange and also hold on the brake backing plate.
No Dana 44 I have ever seen had C-clips but I can't speak for 44's on the current generation Jeeps.
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
