Removed brake booster/MC and now putting it back in - anything special I need to do? - JeepForum.com
post #1 of 4 Old 01-01-2014, 09:45 AM Thread Starter
sevensandeights
I am in the process of building 2 CJ8's out of 3 donors. One will be a bare bones plow Jeep and the other will be a full restomod.
I took the brake booster and master cylinder out of one of the donors and put it on a shelf in my garage for a year. I am now putting it back in the plow jeep (same chassis that the brake set-up came from but different body tub). Is there anything special I need to do? Do I need to bench bleed? If so, any tips?
Thanks and Happy New Year!
sevensandeights is offline
post #2 of 4 Old 01-01-2014, 10:25 AM Thread Starter
sevensandeights
OK - did some research after I posted my question. Looks like I will have to bleed my MC cylinder. Unfortunately, it's already installed in the Jeep. Has anyone used one the syringe type tools to bleed the MC rather than the pieces of rubber tubing and fittings?
http://shop.advanceautoparts.com/web...kit#fragment-3
post #3 of 4 Old 01-01-2014, 01:17 PM
Luke83CJ8
1983 CJ8
You don't have to bench bleed the master cylinder if fluid was kept in the resevoir. On new MC's bench bleeding is to get the air out of the piston below the resevoirs.
However if it wasnt stored with fluid in it and you already installed it you should be able to just bleed the brakes as you normally would (LR, RR, RF, LF) ensuring that there are no air bubbles in the the lines before you are finished.
Luke83CJ8 is offline
post #4 of 4 Old 01-01-2014, 08:14 PM
Spieg8
1984 CJ8
You can bleed the MC while it's on the the Jeep (obviously the brake lines need to be disconnected at the time). Haven't seen that type of bleeder tool before, but I can see how it might work better than the normal recycle tubes. Be sure to report back about how it works if you use it.
Spieg8 is offline
