Regear 456 vs488 - JeepForum.com
post #1 of 19 Old 11-06-2013, 11:37 PM Thread Starter
Hartfamily
1978 CJ5
Regear 456 vs488
456vs488 258 motor, t-18, 33" tires. Top speed 45 to 50 mph. Any recommendation for shop to install in northern cal. Also I would like to install arb locker any thoughts. Thanks mike
Hartfamily is offline
post #2 of 19 Old 11-07-2013, 07:28 AM
CJ7KAHUNA
4.56 if those are the only options - and that was too much for mine w/33's. I'd go 4.10 if I had to do it over and I was going to run 33's. I am running 4.56 w/35's and is perfect for a dual purpose DD/Moderate off road set up IMO.
My childhood was typical. Summers in Rangoon, luge lessons. In the spring we'd make meat helmets.
When I was insolent, I was placed in a burlap bag and beaten with reeds. Pretty standard, really.
CJ7KAHUNA is offline
post #3 of 19 Old 11-07-2013, 09:51 AM
Grumpy_one
1976 CJ5
Those are the gears I'm running with my 35"s as well.
Grumpy_one is offline
post #4 of 19 Old 11-07-2013, 10:34 AM
jdarg
I'd definitely go 4.88 if you are *sure* about that top speed and you are leaning more towards a trail rig and "around town" Jeep than a highway/freeway cruiser.
You'll be at 2600 RPM or so @ 50mph w/ 4.88's.
'94 YJ - SBC/AX15/231, SOA, 8.8, 34" swampers
'06 LJ Rubicon - 31" ATs, OME 2.5", belly-up skid, other junk
'75 CJ5 - 232/T14/D20, 'glass tub w/ 2" BL, otherwise stock
jdarg is offline
post #5 of 19 Old 11-07-2013, 10:46 AM
LumpyGrits
Well, I run 4:88's with my 33's and a T5 tranny.
Love'em.
Really don't think it would be worth it with a 4 speed to go from 4:56 to 4:88.
For trail use, in this case. I would go to a 4 to 1 t'case, and stay w/4:56 R&P.
I have a 4 to 1 t'case also, sure makes "rock'n" easier for sure.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #6 of 19 Old 11-07-2013, 10:59 AM Thread Starter
Hartfamily
1978 CJ5
Thanks all ,off road mostly the jeep is towed on the freeway but driven on highway 50 mph tops, any recommendation for a shop to install proline in San fransico or four wheel parts in Oakland . Thanks mike
post #7 of 19 Old 11-07-2013, 01:47 PM
bspeth
1982 CJ7
driveline and gear service in reno(sparks) was awesome.
82 CJ7 258-98 XJ
bspeth is offline
post #8 of 19 Old 11-07-2013, 01:48 PM
bspeth
1982 CJ7
hey grumpy,you know Sean?,he lives in your AO.
82 CJ7 258-98 XJ
bspeth is offline
post #9 of 19 Old 11-07-2013, 01:51 PM
bspeth
1982 CJ7
go to grimmjeepers web site and put in your info,that gear calculator is dead on. I got my 3.73s in my Cherokee dead nuts at 2390 at 70 mph.
82 CJ7 258-98 XJ
bspeth is offline
post #10 of 19 Old 11-07-2013, 01:51 PM
LumpyGrits
No, I don't.
OK............NOW, that I have my GLASSES on, I see a G and not an L......LOL
LG
post #11 of 19 Old 11-09-2013, 10:06 PM Thread Starter
Hartfamily
1978 CJ5
Thanks everyone for the info. I am looking at 488. Has anyone ever used Oakland four wheel parts?.
post #12 of 19 Old 11-11-2013, 12:34 AM Thread Starter
Hartfamily
1978 CJ5
How good are g2 gears
post #13 of 19 Old 11-12-2013, 08:07 PM
capt205
1983 CJ7
I have G2 sets in both my 2003 F350, amd my 1983 CJ7.
Did the F350 in 2008, and CJ in April of this year. No problems with either one, and I put between 20 and 30,000 miles per year on the Ford, often towing 15,000 lbs.
My opinion...they are gtg
capt205 is offline
post #14 of 19 Old 11-12-2013, 08:32 PM
BlueRubiconrich
why regear your old axles? get Dana 44's with the right gears.
Dana 44 bigger R&P 30 spline axle shafts
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #15 of 19 Old 11-12-2013, 10:25 PM
lucdog
1980 CJ5
Not trying to start a arguement, but..
AMC 20 1 less spline, at 29.
The weak points are the 2 piece shaft to hub, the possibility of spun tubes in the center section, and I believe lighter weight tubes.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
