Regear - JeepForum.com
post #1 of 5 Old 10-04-2011, 08:58 PM Thread Starter
dylan0708
Regear
I'm thinking about regearing I have an 86 cj with a t176 4 speed and an I6 with a weber and header... I want to run 33"s I thing or maybe 35"s what would be the best ratio and still be able to keep good speed on the high way?
dylan0708 is offline
post #2 of 5 Old 10-04-2011, 09:28 PM
chevypowered
1981 CJ7
what are you running now? 4.10 are kinda best of both worlds in my opinion, thats what i am aiming to get for my jeep i have 3.73 now.
chevypowered is offline
post #3 of 5 Old 10-05-2011, 02:38 AM
BagusJeep
1981 CJ7
Try the ratios on this table for 55mph running speeds. A CJ is brick shaped so 55mph is as much as you can hope for without burning a lot of petrol.
4.10 will stretch to a 33" tyre but may be marginal on economy and acceleration for a 35" as you are driving a lot of metal forwards at only 2,200 rpm. You would then find you had to drop to 3rd gear to accelerate and live with a limited and uneconomical top speed as the engine struggles to accelerate and maintain speed.
4.56 is a better range of ratio.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 5 Old 10-05-2011, 03:02 AM
80cj
80cj's Avatar
1980 CJ5
If you happen to have one of the 86 CJ-7's that came out with a Dana 44 rearend, you could go to 4.27 which would be a nice compromise ratio with 35's. If you have the AMC 20, then your choices are narrowed to 4.10's or 4.56. If you decide on 33's 4.10 is a good ratio. Incidentally, your transmission is likely a T-177 with 3.82 first gear. A metal tag fastened to the passenger's side of the case will have one of these numbers stamped on it.
5359389 = T-177 (3.82 first gear)
5359390 = T-176 (3.52 first gear)
80cj is offline
post #5 of 5 Old 10-05-2011, 07:43 AM Thread Starter
dylan0708
The tranny and axles are an 84 the engine is 86
How to regear amc 20 and dana 30 primezero Jeep CJ Forum 4 03-13-2010 05:21 AM
Jp magazine needs to regear. Cherokeester Jeep CJ Forum 54 10-12-2009 12:07 PM
axle regear Pfeifferj Jeep CJ Forum 10 06-04-2009 06:19 PM
Regear cost? 5artist5 Jeep CJ Forum 7 02-06-2007 08:49 PM
Regear... twmattox Jeep CJ Forum 1 06-18-2003 05:22 PM
