Refurbishing OEM aluminum rocker trim? Need some guidance. - JeepForum.com
post #1 of 15 Old 08-21-2012, 06:23 PM Thread Starter
weapon
1983 CJ7
So I have some original trim that I want to put back on the laredo. After I get all the bumps smoothed out with the hammer, I need to help figuring out how to fix some of the gouges and scrapes.
I assume I will get out the nicks and cuts with sanding, then buffing to a mirror finish with pads and glaze.
The real question is how to fix the deeper gouges and the place where the metal is gone due to corrosion with the body metal. Suggestions?
weapon is offline
post #2 of 15 Old 08-21-2012, 06:28 PM
BubbaK
1983 CJ7
I'd like to know the same thing... Subscribing to thread [ now ]
BubbaK is offline
post #3 of 15 Old 08-21-2012, 06:54 PM
PROJECT 23
Aww, wax on
Wax off......
PROJECT 23 is offline
post #4 of 15 Old 08-21-2012, 07:24 PM
Brewski
If you want the look more like OEM then you can clean them and sand as you have stated. Fill the deep pits with JB weld and sand smooth. Also a good filler but pricey is All Metal available from NAPA. It is an aluminum filler compound. I then primered, painted with heavy metalic aluminum paint. I think the paint I used was bright silver for aluminum wheels from Autozone. I then put on a few coats of clear. They turned out really good.
I did first go the route of stripping the anodizing off of them and polishing to mirror finishing but just was not happy with the look.
Brewski is offline
post #5 of 15 Old 08-22-2012, 07:47 AM
CSP
If you want to keep them aluminum, you'll need to find someone that will tig weld the gouges to fill them back in. Once filled it would be up to you if you are able to grind/sand/polish the filled areas back to their original appearance.
Any welding shop should have the ability to do this.
CSP is offline
post #6 of 15 Old 09-11-2012, 03:30 PM Thread Starter
weapon
1983 CJ7
Looks like I made a mistake and ended up buying CJ-5 ones. Now I have to try and offload those and am still looking for a passenger side one is great condition.
Oh the things I do to myself on my jeep rebuild.
weapon is offline
post #7 of 15 Old 09-11-2012, 04:00 PM Thread Starter
weapon
1983 CJ7
mike76CJ5 and anyone who might be interested: Here are the photos of the CJ-5 rockers.
They are in nice shape. The bottoms has a bunch of rock chips which can be sanded out, and there is one major gouge (I took a closeup of it) that will have to be tig welded, sanded and buffed back to shine to get them to show standards.
479154_3846869046605_1257184289_o.jpg   219382_3846864246485_1552291073_o.jpg   339733_3846844886001_68698685_o.jpg   462302_3846835445765_374864440_o.jpg
weapon is offline
post #8 of 15 Old 09-11-2012, 09:39 PM
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
Just a FYI on the rockers. There were two finishes depending on year and trim level. Black anodized and bright anodized. My '85 black Laredo had black anodized trim
that after years of fading began to look silver. I questioned that as well and I think the answers are pretty definitive in this thread:
http://www.jeepforum.com/forum/f8/oe...color-1373279/
'85 CJ-7 Laredo currently under construction.
BlkCJ7Laredo is offline
post #9 of 15 Old 09-11-2012, 10:07 PM
82JeepCJ7
1982 CJ7
Took a sawzall to mine.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #10 of 15 Old 09-12-2012, 06:56 AM
mike76CJ5
1976 CJ5
I'm interested - PM-ing u.
"Know the rules well, so you can break them effectively"
-Dalai Lama XIV
1976 CJ5 Renedade Levis Edition
2012 WK2 Overland
mike76CJ5 is offline
post #11 of 15 Old 09-12-2012, 08:23 AM
cookingguy
1979 FSJ Cherokee
got net cat now white smoke out exhaust
so I just got a new cat put on and now when I start it up I get some white steam and alot some water dripping out of the tailpipe. I never had this befor the new cat got put on. Is the steam due to my new cat and will it go away in time? The jeep has not been run for more than five min or so maybe 4 different times I still have to put on my new fan so don't want to over heat. any ideas on this steam and water
cookingguy is offline
post #12 of 15 Old 09-12-2012, 09:26 AM
82JeepCJ7
1982 CJ7
That's normal with a cat. They get very hot while the engine is operating and when they cool off, they condense a lot of water. That water then makes its way out the exhaust pipe as the engine warms back up.
post #13 of 15 Old 09-12-2012, 10:02 AM
mike76CJ5
1976 CJ5
can the white steam be used for refurbisihing the rocker panel trim? If not, why is the question in this thread?
-Dalai Lama XIV
2012 WK2 Overland
post #14 of 15 Old 09-12-2012, 11:16 AM
stamp32
Exactly
stamp32 is offline
post #15 of 15 Old 09-12-2012, 11:58 AM Thread Starter
weapon
1983 CJ7
Haha. Classic miss-post.
weapon is offline
Rocker panel trim hardware 85LaredoCJ7 Jeep CJ Forum 12 12-07-2011 05:43 PM
WTB-CJ7-OEM Rocker Trim Panels mmillen Jeep CJ Forum 11 06-08-2010 03:45 AM
stock rocker panel trim 82Renegade Jeep CJ Forum 3 10-08-2007 03:21 PM
Rocker Trim Fasteners shelldrake Jeep CJ Forum 4 09-14-2007 06:12 AM
Rocker Trim shelldrake Jeep CJ Forum 10 05-15-2007 07:13 AM
