Redline Holley Weber 32/36 jetting? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Redline Holley Weber 32/36 jetting?
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 05-24-2007, 04:01 PM   #1
52pu
Redline carbs sells a 32/36 set up Holley Weber for all 4 cyl 232/258ci inline 6 cyls & 2.8 V6 engines set up for sealevel altitude and is perfect for these engines. If you've bought one of these pre-set-up carbs you would be doing a great servce to the rest of us if you couild let us know what the following jets are.
Main jets: pri and secondary at the bottom of the bowl
idle jets: pri and secondary outside behind the(small brass screws)
air correction jets: pri and secondary(inside on top of the emulsion tubes)
emulsion tubes: pri and secondary
I've tried by various means to find out from the company but they won't say beacuse they are afraid we will jet a junk yard carb and use their set up. Weber jets are expensive and would save us a lot of time and testing. Thanks in advance from all of us on the board.
52pu
"drive it like you hate it - fix it when its broke"
52pu is offline   Reply With Quote
Unread 05-30-2007, 05:50 PM   #2
52pu
redline holley weber 32/36 jetting?
bump this message up.
52pu
Unread 05-30-2007, 06:56 PM   #3
CJ Chet
Holley Weber? Junk yard carb?
HUH?????????
Beer is the answer - it doesn't matter what the question is!
'86 CJ7, 265 CI, DUI, TF999, Borla, Weber, 4" BDS Lift.
'04 AEV RUBICON.
'00 TJ Sahara.
CJ Chet is offline   Reply With Quote
Unread 05-31-2007, 09:39 AM   #4
Hunt_Nevada
There is no Holley Weber, period. Weber 32/36 carbs are very distinctly different from Holley's. As to the jetting, it is available fm numerous sources. No conspiracy here.
The only bumping this message needs is to the bit bucket.
'85 CJ-7 258 w/Hedman hedders, DUI ign, 2.5" cat/exhaust, Weber 32/36, T-176, Dana 300, Powertrax locker, 32/11.50 muds, Skyjacker 2.5" suspension, Warn 9500HS - a hunter, not a crawler
Hunt_Nevada is offline   Reply With Quote
Unread 06-07-2007, 09:29 PM   #5
52pu
Nevada,
Another uninformed poster. Anyone can do a little search-for example Langdons stovebolt sells the Holley/Weber 32/36 all day long for $65.00. All anyone needs to do is rejet them for application and altitude.
52pu
Unread 06-08-2007, 12:45 AM   #6
Mr.Crowley
1980 CJ7
52pu if your talking about this
http://www.stoveboltengineco.com/aca...?productid=149
that is no holley...they may rebuild it or mr.Stovebolt may just call them that but its just an old weber...A little searching can yeild the base jetting of any weber they make..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
[QUOTE=Me]
"offroad it, and wave then you might understand"[/QUOTE]
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL]
Mr.Crowley is offline   Reply With Quote
