Red line - JeepForum.com
post #1 of 15 Old 03-04-2013, 02:09 PM Thread Starter
Newbjeep
1972 CJ5
Red line
So I got to thinkin and I don't know what my red line is and I buying a tach so I was hoping some would know what the stock red line was on and amc 304 from my 72 cj5
Newbjeep is offline
post #2 of 15 Old 03-04-2013, 02:13 PM
82JeepCJ7
1982 CJ7
Howdy.. live just down the road from ya.
I typically don't go over 4k with my 304.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #3 of 15 Old 03-04-2013, 02:16 PM Thread Starter
Newbjeep
1972 CJ5
Do you know what the stick red line was and why so low
Newbjeep is offline
post #4 of 15 Old 03-04-2013, 02:21 PM
82JeepCJ7
1982 CJ7
304s are not made to rev real high. They make most of their torque in the lower RPM ranges unless you have swapped in a cam that likes 5,000RPM. Once you start getting up in the RPMs, the valve train is not designed for those high revs. The valves start floating first, and then you can see valve failure which can lead to the piston smacking a valve the the S hits the fan real quick.
What trans, axle gears, tires are you running?
post #5 of 15 Old 03-04-2013, 02:35 PM
stroked383z28
1976 CJ5
The stock tach on my 76 304 is shaded from 5k to 6k. The camshaft profile primarily determines what rpm the engine will make peak power. Larger duration will move the power band up. Low end torque, not high rpm power, is typically desired in an off road vehicle.
76 CJ5 Renegade, 304, T150, 3.54 gears, 30x9.5 AT's
stroked383z28 is offline
post #6 of 15 Old 03-04-2013, 02:38 PM Thread Starter
Newbjeep
1972 CJ5
It's a 3 speed with Dana 20 and I have no idea I'd guess stock but idk I bought it a few weeks about has a locker in the back
Newbjeep is offline
post #7 of 15 Old 03-04-2013, 02:47 PM
82JeepCJ7
1982 CJ7
Yea, with that setup, your motor will be happy at 4k and under.
post #8 of 15 Old 03-04-2013, 07:27 PM Thread Starter
Newbjeep
1972 CJ5
My buddy just bought a 56 Willys cj5 and it has the warn overdrive sticker in the glove box and I was wondering where the lever would be
Newbjeep is offline
post #9 of 15 Old 03-04-2013, 08:27 PM
82JeepCJ7
1982 CJ7
With a model 20 T-case, you won't have an overdrive. Those are only used on model 18 transfercases.
post #10 of 15 Old 03-04-2013, 08:30 PM Thread Starter
Newbjeep
1972 CJ5
I read that it does have a 18 is there some thing I an get pics of to show you to know
Newbjeep is offline
post #11 of 15 Old 03-04-2013, 08:41 PM
BuckleshootCJ5
1973 CJ5
My 304 seems to want to explode if I get much over 4,000 RPM's. I set the redline on my tach at 4,000 and usually don't get much over 3,700...
The world would be a better place if being stupid hurt...
BuckleshootCJ5 is offline
post #12 of 15 Old 03-04-2013, 08:41 PM
davbytrace
1979 CJ7
4k is redline on mine.
davbytrace is offline
post #13 of 15 Old 03-04-2013, 09:12 PM
82JeepCJ7
1982 CJ7
I'll have to come up and have a look at it.
post #14 of 15 Old 03-05-2013, 07:48 AM Thread Starter
Newbjeep
1972 CJ5
That'd be ok with me maybe this weekend my buddy works till like six every day and he drives it to work
Newbjeep is offline
post #15 of 15 Old 03-05-2013, 07:52 AM
CSP
Are you talking about yours or your buddie's? Kinda hard to follow who you're talking about.
Have you looked anywhere else on the internet for this information? Google Dana 18 Warn overdrive. You can find all kinds of pictures.
CSP is offline
