Red Hot Front Exhaust Pipe - JeepForum.com
post #1 of 6 Old 09-19-2012, 06:09 AM Thread Starter
drowny
1980 CJ7
Had my 80 cj7 258 running for a while the other day, i normally smell exhaust, but when i looked under the hood the front exhaust pipe coming down from the exhaust manifold was molten red. I also saw exhaust shooting out of the damper flap on the manifold toward the front of the jeep. Could it be clogged converter, timing off or distributor out...or all the above? It drives fine and idles pretty normal.
drowny is offline
post #2 of 6 Old 09-19-2012, 06:17 AM
MoC
I would check the timing to start.
MoC is offline
post #3 of 6 Old 09-19-2012, 06:25 AM
rjbruzan
Is the damper flap open all the way?
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #4 of 6 Old 09-19-2012, 06:36 AM
keith460
Jeep. There's Only One
keith460's Avatar
Red hot exhaust pipe in color usually means a "very lean" condition in the air/fuel mix.
1984 CJ-7 Renegade
keith460 is offline
post #5 of 6 Old 09-19-2012, 06:40 AM
rjbruzan
Or a burned valve. A compression test will verify.
Ron
rjbruzan is offline
post #6 of 6 Old 09-19-2012, 03:31 PM
mlittle
I've seen late timing cause this when the engine was under load.
1985 CJ7, 258 with TBI, Header, T5, 3:54 gears
mlittle is offline
front exhaust pipe DENVAR03 Jeep CJ Forum 11 08-11-2014 06:37 PM
Is my '82 CJ7 Exhaust Front Pipe Special? Zuccus Jeep CJ Forum 3 07-03-2011 06:38 PM
1983 CJ-5 Exhaust Front Pipe 4.2L jeepsta Jeep CJ Forum 3 07-07-2009 09:52 PM
Exhaust Front Pipe CJ5 -Can't Find One redhawk4 Jeep CJ Forum 11 06-05-2009 08:43 AM
CJ-5, Front exhaust pipe spabula Jeep CJ Forum 4 05-22-2009 08:32 AM
