Recommend solvent for carpet glue in tub - JeepForum.com
post #1 of 7 Old 06-29-2003, 04:45 PM Thread Starter
sampson9dk
The inside of my CJ steel tub covered in carpet glue, tar and all kinds of sticky stuff. Its on there good. Can anyone recommend a strong solvent that will easily disolve and clean the gunk. I dont mind scrubbing a little but I want something that is going to work well.
Ideas???
sampson9dk is offline
post #2 of 7 Old 06-29-2003, 08:34 PM
motoxxxguy
1995 XJ Cherokee
Try scraping the majority of it off with a razor blade scraper. Once most of it is gone, it should be fairly easy to get the rest off with mineral spirits, carb cleaner, etc.
-moto
motoxxxguy is offline
post #3 of 7 Old 06-29-2003, 09:04 PM
Strelnikov
Try MEK (methyl ethyl ketone). I got a gallon of it somewhere years ago, probably to clean up old glue on a fabric-covered aircraft frame. Don't use it indoors without proper ventilation, it's quite toxic.
'80 CJ-7 Iron Duke (project)
'99 TJ 4.0 Sahara (daily driver for now)
Strelnikov is offline
post #4 of 7 Old 06-30-2003, 01:03 PM
Yellow Fever
Yellow Fever's Avatar
sampson9dk,
I had to remove the carpet from my CJ7 due to rust on the floor, so I know the problem well. I went to HomeDepo and got this cleaner (don't remember the name, but can find out if you like)that worked great. The only thing is, it'll also take the paint right off. Great for me, because I'm planning on Herculiner the tub, so it saved me an extra step.
Good Luck,
Yellow Fever
95 YJ - 4 Banger
Pro Comp 4" (What a mistake)
BFG 33 A/T with Black Rock Crawler
4:56 Gear
85 CJ7 - 6 Cyl
Currently being Restored
Yellow Fever is offline
post #5 of 7 Old 06-30-2003, 01:57 PM
ace2222
Use POR-15 paint remover!!! it is the best thing in the world take care of everything
ace2222 is offline
post #6 of 7 Old 06-30-2003, 09:32 PM
cj5mudman4x4
I work at a paint store and i recommend goof-off. or laquer thinner would do great. i took sticker residue off with laquer thinner real easy.. and it wont harm ur body paint.M.E.K is a stripper it will hurt ur paint.
HTH
1973 CJ5
258ci I6 rebuilt. bored .40
Painless wiring harness
INDEPENDENT OFFROAD member Bowling Green, Ky
cj5mudman4x4 is offline
post #7 of 7 Old 06-30-2003, 09:37 PM
MudLover
MudLover's Avatar
My friend used Xylene. It was awesome and didn't hurt the paint at all (so his logic told him to Rhino Line it hahaha).
Marc
1979 CJ5 project
"Life is an issue of mind over matter. Ya see, I don't mind, and well...you don't matter."
Red Jeep Club Member #2
MudLover is offline
How to get rid of old weatherstrip glue IDK Jeep CJ Forum 12 10-25-2009 02:30 PM
Rusted Parts Solvent AbsolutXJ Jeep CJ Forum 15 09-24-2008 04:18 PM
What's the best spray-on cleaner/solvent? part.changer Jeep CJ Forum 8 09-01-2007 08:36 PM
Body Panel Glue? YellowTeeJay Jeep CJ Forum 3 12-28-2004 06:18 AM
Best solvent? DaveFL Jeep CJ Forum 9 08-14-2002 05:25 PM
