Rebuilt 258 Overheat, burns oil - Page 2 - JeepForum.com
post #16 of 18 Old 05-15-2012, 04:48 PM Thread Starter
Jeepkid1995
1979 CJ7
Turned it over with no plugs, no water out of any cylinder, fired it up and ran fine. Little white puffs just as I shut it off, nothing else to be alarmed of. Called my rebuilder, and he said to fire it up, and if there is still white, its a head gasket. No white. As soon as I can get the temp gauge working, I'll try and run it for a few minutes again. This is confusing.
Jeepkid1995 is offline
post #17 of 18 Old 05-15-2012, 05:05 PM
walkerhoundvm
1981 CJ8
I missed it, has anyone asked about your intake yet - is it water cooled, i.e. someone replaced it with a later model intake at some point?
What's been done to the exhaust? How much smoke are we talking about here, and it sounds like it's recovering after the first start...it's getting better?
How's your fluid level now? You may want to hoist up the front end and rock it a bit to try to get any air bubbles out of the system, then check and refill. You have an overfill reservoir, yeah?
walkerhoundvm is offline
post #18 of 18 Old 05-15-2012, 07:46 PM Thread Starter
Jeepkid1995
1979 CJ7
No, the intake is stock. It did indeed get better. We removed the thermostat. The water in the radiator was cool, but the water in the block was scalding. Removed the thermostat, and am going to try to run it now. Thanks all
258 , coolant , oil , overheat , water
Wierd overheat NExOBLIVISCARIS Jeep CJ Forum 12 12-10-2011 04:07 PM
rebuilt or not? flashfludjr Jeep CJ Forum 1 03-10-2010 11:03 AM
HELP< OVERHEAT'n SOB ElDuche Jeep CJ Forum 6 04-01-2009 01:36 AM
Is it a rebuilt 258 CJunk Jeep CJ Forum 8 03-01-2009 04:31 PM
problems with 258 overheat, etc edge1 Jeep CJ Forum 2 07-17-2003 09:05 AM
