Rebuilding TF999 whats the cost? - JeepForum.com
post #1 of 13 Old 03-27-2012, 03:37 AM Thread Starter
rainjeep
3 speed auto TF999 rebuild for $600 is that a good price?
rainjeep is offline
post #2 of 13 Old 03-27-2012, 07:02 AM
JeepHammer
Running On Empty...
1973 CJ5
$600 Is VERY reasonable.
There is a lot involved, removal of the transfer case,
Removal of the transmission,
Rebuild of the transmission,
You are looking at about $250 in rebuild parts alone, and that's if none of the hard parts are toast.
Replacing the converter is pretty much mandatory, you don't want a worn converter with little pieces of clutch material/metal in it put back into a fresh rebuild...
That's $75 to $100 right there!
Just make sure you get the 'Towing' type clutches when you rebuild for heavy service if you off road.
If you don't off road, then the standard clutches are fine.
I wouldn't touch it for $600 unless the shop was REALLY slow and I just needed to keep busy.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #3 of 13 Old 03-27-2012, 07:28 AM
JeepHammer
Running On Empty...
1973 CJ5
One other thing that comes to mind,
Before I work on a transmission, I usually change filter, fluid, adjust bands and throttle valve linkage.
Before I tear into one, I usually check the line pressure to the 1st/Rev. clutches and make sure it's not a throttle valve issue.
Too many times I've torn into a Chrysler transmission and found out everything was OK, not real tight, but close enough it should have been working,
Just to find out the plastic bushings in the throttle valve linkage had given up, or the linkage it's self had given up somewhere or was HORRIBLY out of adjustment.
The throttle valve will bypass a lot of the pressure from the pump when the throttle blades aren't open (Idle) and start to pass full pressure to the 1st/Rev. clutch pack when you open the throttle a little...
The idea is, without that extra pressure, there isn't as much wear on the clutches when you are sitting at stop lights, ect. in gear.
When that throttle valve gets misadjusted, you wind up with pressure bypassing the clutch pack when it shouldn't be.
So adjusting the throttle valve, then taking a line pressure reading will tell you pretty quick if it's a weak pump, worn clutches, band that needs adjusting or just plain old age...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #4 of 13 Old 03-27-2012, 01:39 PM Thread Starter
rainjeep
Thank you so much for all the good information. I called the mechanic and instructed him to change the filter,fluid and adjust the throttle valve linkage before we do any major rebuild. hope this fixes it.
rainjeep is offline
post #5 of 13 Old 04-18-2012, 09:48 PM
rrtex1
1981 CJ7
updates?
Round Rock, Texas
1981 CJ7 AMC304
rrtex1 is offline
post #6 of 13 Old 04-19-2012, 08:43 PM
pman
Great advice JeepHammer! I got 3 extra years out of a TF727 doing just that.
As far as rebuild costs, that's an incredibly good deal. 999/727's are not difficult transmissions to work on, and it drives me nuts to hear of shops quoting guys 3+grand for rebuild.
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #7 of 13 Old 04-27-2012, 01:34 PM
SKT
1981 CJ7
Did you have it rebuilt, and if so, how is it doing?
Also, do you have any other pics of your '7 that you could post up here?
It is a sharp looking '7!
SKT is online now
post #8 of 13 Old 06-08-2012, 11:36 PM Thread Starter
rainjeep
I finally got the tranny rebuilt with a new torque converter and is back on the jeep and it shifts better and softer than before. too soft i would say, the only problem that i got to figure out is why is not giving me power uphill or when i want to pass another car when i step down on the gas pedal all the way to the floor. I have to manually down shift to 2nd uphill it never did this before the rebuild. any advice jeephammer?
rainjeep is offline
post #9 of 13 Old 06-08-2012, 11:58 PM
85LaredoCJ7
Sounds like the kick down isn't adjusted correctly....but in could be wrong.
The Dude abides....
85LaredoCJ7 is offline
post #10 of 13 Old 06-09-2012, 02:48 PM Thread Starter
rainjeep
anyone knows the gear shifting points are? Im in 2nd at 15mph and 3rd(D) at 20-25 is this right? Is the kickdown still suppose to work with 35" tires? downshift when floored pedal?
rainjeep is offline
post #11 of 13 Old 10-04-2012, 07:08 PM
Rollbar
1984 CJ8
JH-When using these "Towing Type Clutches" is it wise to use a shift kit, or is on not needed.
Thanks,
Jim
<----Click
<---- Click
Rollbar is offline
post #12 of 13 Old 10-04-2012, 07:18 PM
Oldcraneguy
1982 CJ7
Take it back, the TV linkage needs to be reset, Im suprised they let it out of thier shop like that, and dont wait!...ocg
Oldcraneguy is offline
post #13 of 13 Old 02-03-2013, 04:48 PM
spankyway
After reading all this information, and a few other threads concerning the TF999, I think I'm going to rebuild mine. I have a '94 YJ that won't even move anymore. I wonder if anyone can point me in the direction of a good rebuild kit or is one from Autozone good enough? Do the rebuild kits come with parts to rebuild the pump or is that extra?
spankyway is offline
TF999 ???'s 143hc Jeep CJ Forum 8 04-08-2007 05:14 PM
87 TF999 into a CJ-7 only in a jeep cj Jeep CJ Forum 8 01-10-2007 12:09 PM
Tf999 ckritcoad Jeep CJ Forum 7 08-03-2006 01:22 PM
5.0 to a tf999 liver156 Jeep CJ Forum 4 05-09-2006 11:54 AM
TF999 hawaiian4x4 Jeep CJ Forum 1 07-12-2002 06:21 AM
