Quantcast REar Yoke Removal tips - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > REar Yoke Removal tips
Old 06-20-2008, 02:58 PM   #1
jeepinarkansas
1982 CJ8
I got the rear yoke nut off, just looking for some tips on removing the yoke from the rear diff so I can replace my pinion seal.
Thanks,
Jake
1982 Jeep Scrambler
5.3 Vortec
SOA on 37s
jeepinarkansas is offline   Reply With Quote
Old 06-20-2008, 04:56 PM   #2
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I just use a hammer and "lightly" tap the yoke ears from the backside to slide it off the pinion splines..
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Old 06-20-2008, 05:18 PM   #3
SuB8HaVeN
Wow, mine was so loose that once I got the nut off I was able to just slide it off with little effort. Is that bad?
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline   Reply With Quote
Old 06-20-2008, 06:26 PM   #4
jeepinarkansas
1982 CJ8
I got the yoke off and the seal out. Is it normal to have a little up/down and side to side play on the output shaft?
1982 Jeep Scrambler
5.3 Vortec
SOA on 37s
Old 06-20-2008, 08:12 PM   #5
mcmud
1983 CJ8
Yes it's (end play). Normal once the yoke is pulled since the preload is off the pinion gear. Smear a little gear lube on the yoke and seal surface prior to install. Use a NEW nut, and hopefully you noted the amount of torque required to turn the pinion. Tighten the nut very gradual until end play is removed and then minutely until the amount of originally torque required to turn the pinion is reached then add 3-5 in. lb.
mcmud is offline   Reply With Quote
Old 06-21-2008, 12:08 PM   #6
jeepinarkansas
1982 CJ8
should I follow that procedure even if i neglected to measure the torque before hand?
1982 Jeep Scrambler
5.3 Vortec
SOA on 37s
Old 06-21-2008, 07:10 PM   #7
mcmud
1983 CJ8
How Could You Do It?
That would hardly be possible now, wouldn't it.
The amount of preload on the pinion gear bearing's is critical since you use both forward and reverse motions in the vehicle. the helical cut in the gear actually pushes against the ring gear in forward and pulls against the ring gear in reverse. This requires an enormous amount of force considering the slight area of contact between the two gears. There is a controlled amount of pressure between the pinion's rear bearing and the front bearing controlled by the collapseable crush sleeve between the two bearing faces and a nut that will not back out.
I haven't a clue as to what limits of use you subject the Jeep to or for that matter the level of maintenance your aim is, but I would first suggest you obtain a repair manual or if you have one use it prior to removing any part for a repair.
This fourm is a wonderful location to share experiences, to receive or give opinions and seek advice with issues that are not quite clear or subject to interpretations.
So here is mine. If I were to be forced, i.e. on the road or trail or otherwise unable to properly do the reseal, I would torque the nut to say maybe 35 ft.lbs. after I detented the second from the top thread in three places around the circumference. Then I'd plan to install a new crush sleeve seal and nut ASAP.
Old 06-25-2008, 05:11 PM   #8
OSUAV8R
Oh Crap, I also didnt measure, but mine was so tight I had to use an impact wrench to get it off...So I dont get at what point I could have measured ? Any Advice?
OSUAV8R is offline   Reply With Quote
Old 06-25-2008, 08:00 PM   #9
mcmud
1983 CJ8
The amount of force required to rotate the yoke with rear axle lifted off the surface and both wheels removed.
This measurement has a factory spec. range of 15-25 in.-lbs. to compensate for the expansion caused by heat and load during operation.
A new crush sleeve may be installed after the seal is removed and always use a new nut. The nut is actually deformed to insure that it will not loosen during operation. The force required to crush the sleeve differs but should range between 200-300 ft-lbs at the onset and then it will lessen, continue tightening the nut in small increments to collapse the sleeve and preload the bearings until a very slight increase in pinion turning effort is noted. (This will require a tool to hold the yoke and a long handle wrench and often a cheater bar.) Then remove the tools and check the force required to rotate the pinion using a inch poundtorque wrench. Tighten in very gradual increments until the proper force required to turn the pinion is reached.
Or, simply ask, read, and research before removing any part!
EDIT: Assuming you are running the AMC 20 The Dana 44 uses shims instead of the crush sleeve and requires retorque of 150-200 ft.lbs.
Old 06-25-2008, 09:19 PM   #10
bdmonist
WTF is that?
bdmonist's Avatar
The 15-25 in-lbs of rotating torque on the pinion is without the axles and ring gear installed. It will be more with axles installed.
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
AMC 20 Write Up
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline   Reply With Quote
Old 06-26-2008, 07:42 AM   #11
OSUAV8R
Can I reinstall the old nut measure the torque adn the install a new one adding 5 in-lb to the torque.....or is it to late and I'm screwed?
Old 06-26-2008, 07:50 AM   #12
mcmud
1983 CJ8
Too late. Do you have access to a repair manual?
Old 06-26-2008, 03:54 PM   #13
OSUAV8R
I have the Hayes manual and chilton.
I have not touched the yoke yet, if that makes a difference
Old 06-26-2008, 04:25 PM   #14
Bard
The original preload is when you set the pinion in and crush the crush collar. I just replaced my yoke, since I snapped the ears off and just used an impact gun until it was tight. I replaced the seal as well and dust cover. You can torque it to spec or to what it was replaced to if it was replaced, but if you didn't touch the pinion besides the yoke and seal, just go until tight.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline   Reply With Quote
Old 06-26-2008, 07:53 PM   #15
mcmud
1983 CJ8
Just a few dollars
Suggest you go and make a wise investment in you and your Jeeps future. Your local SEARS likely will stock a inch-pound beam torque wrench and allow a simple process like the seals replacement to be done properly and effectively. Read your manuals as the both you have will have the very same directions. An improper install can lead to incorrect gear wear ( .0001 pinion movement will drastically alter the wear pattern considerably and could lead to something breaking.
Glock Forum
