Rear window shocks??? - JeepForum.com
 1Likes
post #1 of 32 Old 11-12-2012, 06:10 PM Thread Starter
BeesJeep
1981 CJ7
Does anyone know where you can get new shocks for the rear window on a CJ7 hardtop? I have seen some used ones on Ebay, but they are probably no better than what I have. I think Auto Zone sells some, but I don't know if they have any close to the size I need.
BeesJeep is offline
post #2 of 32 Old 11-12-2012, 07:49 PM
Bubba Ray
If you have old ones that worked then take them to NAPA and match them up. Just do not trash the old ones until your sure the new ones are the correct pressure or strength. Struts with too much pressure can break the mounts in the hardtop. It is a real pain to fix.
Bubba Ray is offline
post #3 of 32 Old 11-12-2012, 08:15 PM
wellmax
what he said, do not throw away your old ones yet.
have you taken them off and poured lube in the vent hole at the bottom, just be sure they are properly lubed.
I do not remember for sure, but i sprayed wd40 or some other type lube on the shaft and try to get lube inside to the spring.
redneck solution: press the lift springs on a bathroom scales and seen how many pounds the scale reads when you compress the spring. this would give you a starting point in looking for new springs.
also you must have the length of the lift spring: compressed and full extention.
Remember: to buy new lift cylinders: you must know required length: compressed, full extention and max lift pounds
to get max lift pounds guess you must devise a way to weigh the lift gate. then divide by 2 as you have 2 lift cylinders.
wellmax is offline
post #4 of 32 Old 11-12-2012, 08:23 PM
wellmax
your old jeep looks alot like mine
wellmax is offline
post #5 of 32 Old 11-12-2012, 08:38 PM Thread Starter
BeesJeep
1981 CJ7
Thanks for the tips. I will try to lube them first, I am all about redneck solutions!
BeesJeep is offline
post #6 of 32 Old 11-12-2012, 09:10 PM
82JeepCJ7
1982 CJ7
The original lift gate struts do not have any hydraulic pressure in them. They are simply two tubes with a spring inside.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #7 of 32 Old 11-13-2012, 06:48 AM Thread Starter
BeesJeep
1981 CJ7
So what happens to them? Does the spring break or does the compression wear out?
BeesJeep is offline
post #8 of 32 Old 11-13-2012, 08:25 AM
CSP
Could be either one.
CSP is offline
post #9 of 32 Old 11-13-2012, 08:28 AM
CJ7ROB
I have some good used ones I was holding onto as spares. Let me know if your interested in them, thanks.
CJ7ROB is offline
post #10 of 32 Old 11-13-2012, 09:18 AM Thread Starter
BeesJeep
1981 CJ7
ok, thanks. I will see what I can do with these first.
BeesJeep is offline
post #11 of 32 Old 11-13-2012, 11:57 AM
keith460
Jeep. There's Only One
keith460's Avatar
If you can't repair you OEM springs, McMaster-Carr has gas struts available that you can adjust the gas pressure to what is needed in order to lift and close the rear hatch. There is a bleed screw on them that allows gas pressure to escape so they become softer until you have the correct pressure needed to do the job. We use them all the time at my place of business on our bakery equipment. There called: Reducible-Force Gas Springs
1984 CJ-7 Renegade
keith460 is offline
post #12 of 32 Old 11-13-2012, 02:52 PM
Renegade82
1982 CJ7
If you have a fiberglass hatch DO NOT use the original spring loaded shocks on it. They are too strong and will pull the inserts right out of the fiberglass. The stock hatch was much heavier.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #13 of 32 Old 11-13-2012, 11:07 PM
matthewleeblair
1983 CJ7
Would these work?
Check this out on AMZN: Stabilus Lid Stay Gas Spring Medium Duty (Pair) Silver http://amzn.com/B000LY1NPQ
matthewleeblair is offline
post #14 of 32 Old 11-14-2012, 12:26 AM
82JeepCJ7
1982 CJ7
I went out and measured my hard top. Compressed the struts need to be 12.75" and extended about 20" center to center.
Using these dimensions, I found these struts.
http://www.autopartsbylou.com/lift-s...?item=60115M10
post #15 of 32 Old 11-14-2012, 12:28 AM
82JeepCJ7
1982 CJ7
Their website calls for these http://www.autopartsbylou.com/lift-s...=mmy&x=23&y=11 but they would be too long.....
