Rear suspension - JeepForum.com
post #1 of 5 Old 03-11-2013, 06:07 AM Thread Starter
Mlaughlin8
1980 CJ5
Rear suspension
I am curious about replacing my rough 4" superlift rear springs with a stock spring sprung over... Would this be a smart decision? Would the lift be about the same or taller? Right now I have the 4" sping and 1/2" shackles with spring under, I want to put the the stock rear spring back on with no shackle lift with spring over! My front is nice but the rear is stiff. I am trying to achieve a softer more flexy rear suspension, would this work?
Mlaughlin8 is offline
post #2 of 5 Old 03-11-2013, 07:19 AM
Truck633
GO ONE MORE!!
Truck633's Avatar
You may get an unlevel look....
We did the SOA on my buddies CJ5 and it ended up about 6 inches higher after it was all finished. I don't recall how much it was off, but it was quite a bit!
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #3 of 5 Old 03-11-2013, 02:53 PM Thread Starter
Mlaughlin8
1980 CJ5
Did you do the soa to just the rear?
post #4 of 5 Old 03-11-2013, 02:57 PM
CSP
The amount of lift you get out of SOA is pretty easy to figure out. Take the diameter of the axle tube, add 2x the thickness of the spring packs and 2x the thickness of the spring perch and you're done. Should be somewhere around 5.5"-6" with stock CJ axles.
CSP is offline
post #5 of 5 Old 03-11-2013, 03:14 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
Front and rear, if I recall, it was about 6 1/2 inches... Looked great, introduced an axle wrap problem though!
Truck633 is offline
