Rear shackle bracket bolt size - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Rear shackle bracket bolt size
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueRIGID LED Light Blowout Sale - All Sizes, All Series, all End of Summer Sale, 20% OFF!
Unread 04-26-2014, 02:39 PM   #1
ch51670
Does anyone know the size of the four bolts used to mount the stock rear shackle brackets? Thanks
ch51670 is offline   Reply With Quote
Unread 04-26-2014, 03:50 PM   #2
CJ7Kid
My stock ones were 3/8" with sleeves. My new aftermarket grease able shackles have 1/2" bolts. Drilled for grease fittings.
CJ7Kid is offline   Reply With Quote
Unread 04-26-2014, 03:57 PM   #3
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Those should be 7/16"-14 thread..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Unread 04-26-2014, 04:05 PM   #4
ch51670
CJ7kid, not the shackles, the shackle brackets.
BESRK, do you know the length? Thanks
Unread 04-26-2014, 04:10 PM   #5
Jim1611
Jim1611's Avatar
7/16-14 is correct and 1 1/4" is good for the length. Be sure to slather the bolts with a copper based anti-seize too.
Jim1611 is offline   Reply With Quote
Unread 04-26-2014, 04:15 PM   #6
ch51670
Thanks All
Unread 04-26-2014, 09:33 PM   #7
80cj
80cj's Avatar
1980 CJ5
If you have the factory draw bar, the rear bolt should be around 1 3/4" long.
80cj is offline   Reply With Quote
