Rear passenger brake locking up. - JeepForum.com
post #1 of 5 Old 02-11-2013, 08:42 PM Thread Starter
jason400
I noticed that my rear right brake was locking up when I was almost at a stop. I noticed there was a lot of dirt and grime stuck the dust cover, most likely a leak. What could be causing this? Should I replace the brakes and cylinders and springs?
jason400 is offline
post #2 of 5 Old 02-11-2013, 11:36 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
You will need to remove the drum to see if the problem is the brake wheel cylinder or an axle seal leaking.
Both are replaceable.
jeepdaddy2000 is offline
post #3 of 5 Old 02-12-2013, 08:06 AM Thread Starter
jason400
Thanks,
I have the entire brake kit ordered with new cylinders and shoes and springs. I will do the wheel bearings and seals at the same time on both sides. I am sure neither have been touched since 85 since the jeep only has 50K on it.
The brake adjuster is froze, so I am sure all needs to be replaced. Just gives me an excuse to work on it.
jason400 is offline
post #4 of 5 Old 02-12-2013, 08:10 AM Thread Starter
jason400
Anyone know the best place/price to get new bearings and seals?
jason400 is offline
post #5 of 5 Old 02-12-2013, 09:45 PM
Double8racer
I walked into the autozone by me and got new Timkin bearings and race(S) they had to get seals out of the hub but had them all same day
Double8racer is offline
brakes , locking
