Rear main seal on 258 - JeepForum.com
post #1 of 3 Old 01-24-2002, 10:45 AM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
Lightbulb Rear main seal on 258
Does anyone have instructions on how to replace the rear main on an 85 CJ7 with a 258ci engine? T5 trany....
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #2 of 3 Old 01-24-2002, 08:40 PM
hamyscj
Post
Remove oil pan, remove rear bearing cap, slide old seal out, slide new seal in, clean and oil bearing, install rear bearing cap, torque to 80 ft/lbs, install oil pan, change oil filter, add oil, done. In a nut shell, of course. If you are lucky, the oil pan will come off with out too much beating on it. The right motor mount bracket will have to come off in order to remove the pan. One more tip, trust me on this one, get a one piece oil pan gasket for a 4.0. Either from the dealership(they offer a set, op gskt and rear main) or from aftermarket. Carquest has them or Napa. Stay away from the generic stuff. Go with Victor or Felpro. Trust me, it will work and be much easier to install. Read the instructions that come with the gasket as they will most likley tell you to RTV the small holes shut in the timing cover where the old gasket "tits" went in as the new one piece has no "tits". (It is still a better gasket ) Be ready to get oily up to your armpits unless you have a lift. Later, Hamy.
One Way Up Racing
Romans 10:9
hamyscj is offline
post #3 of 3 Old 01-24-2002, 10:11 PM
122345Benny
Post
Check the P.c.V. valve when I bouth my Cj it had oil all over. The preson who had it had changed the pan gasket three times. I found the pcv pipe pluged tight good lucj
122345Benny is offline
Rear Main Seal? mhodson187 Jeep CJ Forum 2 01-26-2010 02:36 PM
Speedy Seal - Leaking Rear Main Seal h2obuff Jeep CJ Forum 18 11-22-2009 07:16 PM
rear main seal 258 VaCJ79 Jeep CJ Forum 14 04-07-2008 10:13 PM
Rear main seal EDs Jeep Jeep CJ Forum 10 01-30-2007 06:50 PM
Rear main oil seal, CJ5, 4-151 aggiedad3 Jeep CJ Forum 1 11-26-2004 01:12 PM
