rear main seal - JeepForum.com
post #1 of 7 Old 12-08-2002, 05:37 PM Thread Starter
jeepdad40
rear main seal
I've checked the previous topics about replacing the rear main seal , the only question I have is do I need to take off the motor mounts to remove the oil pan on an AMC 304 engine? It looks like they are going to be in the way of the pan , but I'm hoping to get away without having to remove the mounts. Thanks!
jeepdad40 is offline
post #2 of 7 Old 12-08-2002, 08:46 PM
Crash&Burn
assuming it's in a CJ, there should be plenty of room to remove the pan.......
1979 CJ7 (YJ tub) full cage, Currie 9inch rear with Warn full float kit, detroit locker, 456 gears both ends, Lockrite in front, T 18 trans, 360, 040 over, Isky cam, 2 into 1 Flowmaster exhaust
I'm not as good as I once was....but I'm good once as I ever was.
Crash&Burn is offline
post #3 of 7 Old 12-08-2002, 09:09 PM Thread Starter
jeepdad40
yes, it's an '83 CJ. It just appears that the ends of the motor mounts extend under the oil pan so that the pan wouldn't drop down freely. I am wondering if I will need to remove the mounts, or if hopefully I can manuever the pan between the mounts. Only reason I ask is because I will do the job myself if I don't have to remove the mounts. BUT if the mounts gotta come out I will take the jeep to a pro to do it , as I am a LOUSY mechanic.
post #4 of 7 Old 12-09-2002, 02:47 PM
CJMONEYPIT
The mounts do not have to come off, but you will have to loosen them quite a bit. Once they're loose, lift the motor an inch or two and you should be able to maneuver the pan around the mount. good luck.
CJMONEYPIT is offline
post #5 of 7 Old 12-09-2002, 09:45 PM Thread Starter
jeepdad40
Thank you for the reply. your username is right on! If my jeep was any other vehicle I would never have bought it, or I would have surely sold it by now!!! I love it so much though that I'm willing to spend most of my free time and money on it!
post #6 of 7 Old 12-10-2002, 09:15 AM
boredstiff
oil pan
I agree with the above, just completed the same thing on my 360. I had to loosen the mounts and lift the engine about 2 inches. After that it took a bit of work but it was better than taking the mounts off.
John
boredstiff is offline
post #7 of 7 Old 12-10-2002, 11:07 AM Thread Starter
jeepdad40
Thanks John!
Rear Main Seal? mhodson187 Jeep CJ Forum 2 01-26-2010 01:36 PM
Speedy Seal - Leaking Rear Main Seal h2obuff Jeep CJ Forum 18 11-22-2009 06:16 PM
rear main seal 258 VaCJ79 Jeep CJ Forum 14 04-07-2008 09:13 PM
Rear main seal EDs Jeep Jeep CJ Forum 10 01-30-2007 05:50 PM
Rear main oil seal, CJ5, 4-151 aggiedad3 Jeep CJ Forum 1 11-26-2004 12:12 PM
