Rear main Seal - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Rear main Seal
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSavvy Aluminum BumpersThe RuffStuff "I can't go to EJS" Sale!
Unread 12-14-2013, 09:56 AM   #1
climberman
1979 CJ5
Rear main Seal
I need to change the rear main seal and have a couple of question. Everyone at the auto-zone needed to know if I have a single or a double seal. How do I know?? It is harder to change a single we have a 258 I think it is an 1980 but then doing some research I think it is a 232 from around 1979 we bought it from a kid that had it in a CJ7. Here is the code on the block. 906 E 16
Thanks
Rocky
climberman is offline   Reply With Quote
Unread 12-14-2013, 12:12 PM   #2
LumpyGrits
IIRC, the only '6' then was a 258. Doesn't mean a 232 hasn't been put in somewhere along the line.
Best to pull the seal out, and take it with you.
Stay away from that China made crap!
NAPA is where I would go
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote
Unread 12-14-2013, 01:28 PM   #3
climberman
1979 CJ5
Thanks I bought both because when I pull the pan I want to finish the job. The question is does the 232 have a seal that is one piece. And if so how hard will it be to change. Is it the same or harder then the two piece
Unread 12-14-2013, 02:06 PM   #4
WindKnot
WindKnot's Avatar
1977 CJ7
It's the same part.
The two piece seal is easy. If it's a one piece you'd need to remove the crankshaft and all that entails. You don't want that.
Be kind. If for no other reason, it will confuse the daylights out of people and make them wonder what you're up to. And ALWAYS drink upstream of the herd!
WindKnot is offline   Reply With Quote
Unread 12-14-2013, 03:43 PM   #5
climberman
1979 CJ5
I hate to keep asking the same question you mentioned that it is the same part so am I going to find a 2 piece rear main on my motor. Because it is like you said you don't want it to be a one piece. I think the auto parts just have me nerves because they gave me two different seals and said one of them is a single piece. But when I open them bother up they are both two piece. They are a little different there is a grove in one of them but I should have the right one.
Unread 12-14-2013, 04:47 PM   #6
strvger01
1966 CJ5
the 232 and 258 engines shared the same basic engine block. should work for you.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline   Reply With Quote
Unread 12-14-2013, 05:03 PM   #7
climberman
1979 CJ5
Thanks for all help Monday is the day a friend is letting us put on his lift so that will make it easier.
Unread 12-14-2013, 05:10 PM   #8
WindKnot
WindKnot's Avatar
1977 CJ7
A two piece seal is easy. The big NO NO is to scratch or mar the crankshaft. You can avoid doing this by pushing the old sea out with a wooden dowel or something similar like plastic. And don't force anything. You can lube the outside with dish soap and the inside with oil. (I used assembly lube.)
If your buddy has a lift, it sounds as if he's no amateur. He'll/you'll do fine. Just take your time.
Unread 12-14-2013, 05:15 PM   #9
climberman
1979 CJ5
Right he restores cars as a hobby and he will be there. Will be slow and careful for sure.
