rear main explosion - JeepForum.com
post #1 of 4 Old 02-28-2013, 09:33 PM Thread Starter
wagonator
1968 CJ5
rear main explosion
guys ive got my self in some deap poo. my 68 cj5 with a f 134 engine, has eatin its rear main alive! i cracked into it and its got an aftermarket one already but its the rubber/silicone. ive bought the old school rope one to replace it but i can't get the top part out. if i loosin the main caps will that give me enough head way to dig that one out? being sure not to score anything will im neck deap in this.
wagonator is offline
post #2 of 4 Old 03-01-2013, 12:40 AM
80cj
80cj's Avatar
1980 CJ5
When changing rear mains seals, it is usually part of the procedure to loosen the main caps to allow the crank to drop down a little.
80cj is offline
post #3 of 4 Old 03-01-2013, 07:51 AM
Balvar24
1979 CJ7
Is the oil slinger in bad shape? If you've got the pan off, you might as well measure end-play on the crank. That could be your problem.
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
post #4 of 4 Old 03-02-2013, 02:51 AM Thread Starter
wagonator
1968 CJ5
What's the slinger?? And how much will the crank drop down?
