Rear fender clearance - Page 2 - JeepForum.com
post #16 of 37 Old 08-28-2011, 02:17 PM
Mike Romain
I turn 33x9.5's with a 2.5" spring lift and .5 YJ shackles and stuff them pretty good with no issues. Frankly when I went from a 10.5 to a 9.5 in the same tread, the traction 'increase' was phenomenal. i went from floating loose at 45 mph in a snow storm to being able to keep up to the transport trucks at 55-60 now with no steering float at all.
Off road, same deal, the boys with the fat tires laugh at me...Once... Then they spend the rest of the day trying to get where I am sitting taking photos of them trying and trying and..... LOL! They just don't spin and almost take the fun out of mud running. If I have to clean all the mud out from under, I want some on top to show for it dammit.
Mike
Mike Romain is offline
post #17 of 37 Old 08-28-2011, 05:52 PM
80cj
80cj's Avatar
1980 CJ5
I run 32 x 11.50 BFG MT's with a Skyjacker 2" lift and have had no problems. Especialy the last month just sitting in the garage.
80cj is online now
post #18 of 37 Old 08-28-2011, 06:43 PM
NoNative
Originally Posted by hogbed
My '80 CJ7 with 2 1/2" soft ride suspension lift and 33x12.50's never had a problem and have been all or Colorado on all the trails. Heck I've even pulled my 16' car hauler trailer (empty) with no problem.
Might have something to do with your TJ flares
1986 CJ-7 Laredo, 258, AX15, AC Dana 30/44, Ox Lockers, Howell TBI, DUI, 4.5" RE YJ Springs, 1.25" BL, clocked & twin-sticked Dana 300 with Lomax 4-1, 4.10s, 33s, PB, 8000# winch, YJ Roll Bar, Factory 20 gallon tank.
1984 CJ-7 Renegade, 258, T4, AC, Howell TBI, DUI, 2.5" OME YJ Springs, 3.53, 31s, PB, Warn bumpers & 8000# winch, Factory 20 gallon tank
1984 CJ-7 Renegade, 258, Auto, AC, 3.31s, PB, Factory 20 gallon tank, Bone stock except for 31s
NoNative is offline
post #19 of 37 Old 08-28-2011, 06:50 PM Thread Starter
85LaredoCJ7
I believe those are YJ flares.....
The Dude abides....
85LaredoCJ7 is offline
post #20 of 37 Old 08-28-2011, 11:37 PM
mvigo
mvigo's Avatar
Originally Posted by 85LaredoCJ7 View Post
Yes..without the BL you would be hitting the rear corner?
correct, or at least I think I would...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #21 of 37 Old 08-29-2011, 12:15 AM Thread Starter
85LaredoCJ7
Wow......hitting the rear edge of the fender with 32s......what to do....what to do. I am really in no mood to trim sheet metal....
The Dude abides....
post #22 of 37 Old 08-29-2011, 10:14 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Tim,
I put mine thru a pretty good test this weekend, including a couple of frame-twister mud holes, and it never rubbed with 32 x11.5 x15s.
Still working on getting pics for you...hopefully this rain will move thru soon.
Matt
Matt1981CJ7 is offline
post #23 of 37 Old 08-29-2011, 10:58 AM
80cj
80cj's Avatar
1980 CJ5
85Laredo CJ7, wouldn't 32 x 11.50 X 15's be better riding than 265 75R16s? My friend bought some 265's for his Toyota truck and those things seem very heavy and stiff. One thing Iimmediately noticed when I put the 32 x 11.50 BFG MT's on my CJ-5 was that the ride really smoothened out compare to my previous 31 x 11.50's.
80cj is online now
post #24 of 37 Old 08-29-2011, 11:30 AM Thread Starter
85LaredoCJ7
Yeah.....they would for sure be smoother.....the 265s are E rated....so yeah stiff and heavy. Nitto makes their trail grappler in a 285/70 16 that wouldn't be bad. BFG also makes their A/T in the same size. I was just trying to get a 16 to work just for being different and the improvement in looks.
The Dude abides....
post #25 of 37 Old 08-29-2011, 12:01 PM Thread Starter
85LaredoCJ7
Here is my problem...if you want to call it that. It still has room to go, so I really want to keep the full flex of the OME leafs. When I looked at it at this point, their was still quite a bit of room with these 30" tires.....but it's hard to judge.
The Dude abides....
post #26 of 37 Old 08-29-2011, 02:03 PM
80cj
80cj's Avatar
1980 CJ5
Watch the rear corner of the rear fenders. That's where the interferece will be. I ran 33's with 2" lift and there were times when the tires got really close to that corner. I decided to go to 32's. No problem, lots of clearance there.
I think if you have equal flex in the front and rear suspension, it really helps. When I ran my 33's, initially I had the sway bar still connected and I noticed it forced the rear suspension to do most of the flexing. Once I disconnected the sway bar, it allowed the front suspension to flex and I noticed there were fewer instances where the rear tires had to tuck into the fenders as previously. Things still got pretty close, though so that influenced my decision to go to 32's. Plus I got the 32's at a really great price. That always helps.
80cj is online now
post #27 of 37 Old 08-29-2011, 02:55 PM Thread Starter
85LaredoCJ7
Yep.....I think a narrower 32 will be fine...now I just have to figure out what flavor in 16". The nitto trail grappler looks good and it is siped and a D rating. It is a 285/70 16....so it equates to a 32x11.50 16. Still waiting for matt to put up some close up of his 32s stuffed in the rear since we are running the same suspension.
The Dude abides....
post #28 of 37 Old 08-29-2011, 03:56 PM
Matt1981CJ7
1981 CJ7
Wait no longer....here's the pics you requested.
OME 2.5" YJ spring lift, stock shackles and steering, with 32"/11.50/15s.
Matt
post #29 of 37 Old 08-29-2011, 04:10 PM
keith460
Jeep. There's Only One
keith460's Avatar
^^ Those are the best pictures anyone can ask for^^
1984 CJ-7 Renegade
keith460 is offline
post #30 of 37 Old 08-29-2011, 04:38 PM Thread Starter
85LaredoCJ7
Yes they are.....can't wait to get home so I can see them on a real screen and not the blackberry......I knew I should have brought the iPad. And damn.....I love Colorado Matt. Last time I was there I drove in a blizzard from Durango to a cabin on Valecito Lake
The Dude abides....
Bolts in rear fender above tire v. Not? Conch Cruiser Jeep CJ Forum 7 01-24-2011 07:42 PM
Rear fender trimming for 35's Coiz Jeep CJ Forum 3 03-16-2009 08:51 PM
rear fender well trim tshuelsman Jeep CJ Forum 6 08-18-2008 09:24 PM
Stock CJ Rear Fender Flares... certifiablejeep Jeep CJ Forum 2 11-13-2007 06:49 PM
82 CJ & 87 YJ Rear Fender Flares.....same? KSToyz Jeep CJ Forum 10 09-27-2007 02:55 PM
