Rear exhaust pipe braket-83 CJ - JeepForum.com
post #1 of 7 Old 03-25-2012, 05:10 PM Thread Starter
Ollie09
1983 CJ7
Trying to figure out where this bracket mounts. It seems like I took lots of pictures during the teardown, but never the RIGHT one. This was mounted somewhere on the left rear and held the tail pipe. Damned if I can figure where it mounts!
Thanks,
Gary
Ollie09 is offline
post #2 of 7 Old 03-25-2012, 05:16 PM
VACJ7
VACJ7's Avatar
There is a plate that bolts to the frame with that one bolt in your other thread. The piece with the rubber isolator bolts under that plate. The piece in the isolator attaches to pipe with muffler clamp.
Here.... bolts underneath this:
'84 CJ-7 |
VACJ7 is offline
post #3 of 7 Old 03-25-2012, 08:08 PM
inovermyhead2
Actually it mounts underneath the bracket that is welded to the frame on the drivers side just in front of the leaf spring mount. The parking brake cables mount to it as well. I don't have a pic handy but the bracket has an arch cut out in it for muffler clearance. BTW, that is the muffler mount, not the tailpipe mount.
1983 CJ7
350ci Chevy
SM465 Trans
Rancho 2 1/2" lift
Confer Engineering Shackles
32x11.50x15 BFG All Terrains
whoever invented Torx bolts should be shot in the face, burned then pissed on - saskcj7
inovermyhead2 is offline
post #4 of 7 Old 03-25-2012, 08:13 PM
VACJ7
VACJ7's Avatar
Your'e thinking of the other one that is more square. I just bolted it in the other day. The one pictured is for the very end of the tailpipe.
'84 CJ-7 |
VACJ7 is offline
post #5 of 7 Old 03-26-2012, 10:51 AM Thread Starter
Ollie09
1983 CJ7
Thanks, I remember taking it off but.......I seem to have lost that bracket.
Gary
Ollie09 is offline
post #6 of 7 Old 03-27-2012, 03:50 AM
trebor3009
Is this a pic of your original bracket and isolator, or is this a replacement. Mine rotted away years ago and I've yet to locate a replacement. Were you able to locate an aftermarket or OEM one?
trebor3009 is offline
post #7 of 7 Old 03-27-2012, 06:56 AM
VACJ7
VACJ7's Avatar
It's original. My rear hanger like the OPs is completely rusted apart. I am going to have to fab one since I have seen neither for sale anywhere.
'84 CJ-7 |
VACJ7 is offline
Exhaust Manifold to Exhaust Pipe Studs NelsonATC Jeep CJ Forum 3 07-25-2011 07:43 PM
Exhaust - Seal between Heat Valve and exhaust pipe Woolys_CJ7 Jeep CJ Forum 1 01-22-2010 07:07 AM
Exhaust pipe for cj-6 ziv Jeep CJ Forum 4 03-09-2008 08:13 AM
151 Exhaust pipe weprint Jeep CJ Forum 2 10-12-2005 01:01 AM
Cracked exhaust pipe (on middle pipe from manifold) tholmes3 Jeep CJ Forum 0 02-18-2003 10:03 AM
