Rear End Thud! - JeepForum.com
post #1 of 8 Old 03-11-2010, 12:51 PM Thread Starter
ckritcoad
Rear End Thud!
I just put a 9" rear end in the CJ. Everything went fine, but when I put it in drive or reverse the pinion jolts pretty violently and makes a pretty bad noise. Is this a back lash problem...would the pinion bolt not being torqued enough cause this?
Thanks for your help!
ckritcoad is offline
post #2 of 8 Old 03-11-2010, 01:35 PM
78treehugger
1980 CJ7
Looks like you have an auto. Is the axle rotating causing the pinion to load an unload? Are your perches good? Did you rebuild the axle before installing it? If not did you check the bearings?
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage
It's easier to get forgiveness than permision.
Salad is what food eats!!!
78treehugger is offline
post #3 of 8 Old 03-11-2010, 02:41 PM Thread Starter
ckritcoad
I got the center section and supposedly it was just built and run for 400 miles with no problems. I changed the yoke to the correct size and installed new axles. The spring perches are good and solid. It does feel like it is loading and uloading when I put it in drive or reverse...yes it is an auto.
FYI it is a LSD. The bearings looked good and I didn't feel any slop or movement.
post #4 of 8 Old 03-11-2010, 03:58 PM
UPJ Wheeler
Make sure your U bolts are tight for the springs. Mine tend to loosn up over time, and then the axle will rotate about 20 degrees or so and make loud banging noises when getting on or off the gas. Simple Fix
'79 CJ7, rebuilt 258, HEI, T5 World Class, D300 Low max 4:1, Flat Belly, Narrowed D44 w/ true trac & diff gaurd, Widetrack AMC20 w/ superior shafts, Detroit locker & crane diff cover, 4" skyjacker lift, 2" BL, TJ flares, 35" tires, York OBA, YJ tub conversion, 6 pt. cage, F250 front shock towers
4.0 Head and TBI on the way
UPJ Wheeler is offline
post #5 of 8 Old 03-11-2010, 04:07 PM Thread Starter
ckritcoad
They are good and torqued down...I will try them again though.
post #6 of 8 Old 03-12-2010, 08:24 AM
CSP
It's either backlash or bad ujoints.
CSP is offline
post #7 of 8 Old 03-13-2010, 05:13 PM Thread Starter
ckritcoad
Amazingly enough it was my U bolts. Apparently my compressor and gun are extremely week. I figured I had torqued them down too much, but when I had it at work in our shop and checked them with a digital torque wrench they were only torqued down between 35 and 45 ft/#'s. I torqued them to 100 and they problem completely went away. Thanks for the suggestion!
post #8 of 8 Old 03-14-2010, 07:31 AM
UPJ Wheeler
no problem....
rear axle leaking on 84 cj7,AMC20 rear end swjohnson5 Jeep CJ Forum 12 11-24-2012 02:03 PM
jeep rear end with ford rear end swap? jdp492001 Jeep CJ Forum 3 09-19-2009 07:01 PM
Rear end on jacks, can't turn rear axles by hand DT5150 Jeep CJ Forum 10 03-20-2009 07:17 AM
Why dont I have a rear shackel on my rear springs rescuetech Jeep CJ Forum 9 07-05-2008 03:49 PM
stock rear bumper? Tow points in the rear... jlr69s Jeep CJ Forum 17 05-15-2008 07:23 AM
