rear-end suggestions - JeepForum.com
post #1 of 3 Old 01-20-2002, 12:21 AM Thread Starter
WarnRocker79
Post rear-end suggestions
I am looking to put new gears in my jeep. It has an inline 6 in it. I am wanting to have real power but still be able to drive on road some. Any suggestions would be helpful, and any brand names would be good too.
Jayson
79 Cj-5 258 I-6
32/12.50s Generic Mud tires
Slowly rebuilding into a monster
WarnRocker79 is offline
post #2 of 3 Old 01-20-2002, 10:01 AM
Darko
Post
what kind of trans and tires are you running. IF you are going to the trouble of adding gears, maybe you should consider a locker and axle shafts if it is all apart, or you could just swap in a D44. If you go with higher gears (4.88+) I would suggest keeping the M20 because the ring gear is 8.875" wide where the D44 is only 8.5" wide. The axles have almost the same spline. The D44 has 30, and the M20 has 29. With one piece axles, and welding your axle tubes to you diff housing would make the M20 just as strong as the D44, maybe stronger.
Found a 85 CJ7 tub in good shape with
minimal rust. The resto continues....
Darko is offline
post #3 of 3 Old 01-21-2002, 02:40 PM
clegger
Post
If you do plan on keeping the AMC20, make sure you have it straightend. Those axles are known for turning into bananas.
78' CJ-5 in process of frame off, 84' V8 Ranger
clegger is offline
Suggestions for Purchase of Front and Rear Lockers mjr03c Jeep CJ Forum 9 04-15-2009 07:53 AM
Rear spider gears blew and suggestions Kwish Jeep CJ Forum 7 01-07-2009 03:37 PM
Suggestions for a cheap rear bumper wwhitby Jeep CJ Forum 8 09-28-2006 01:31 PM
Frozen rear drums...suggestions? GroundUpCJ7 Jeep CJ Forum 4 06-02-2003 07:54 AM
Thinking about swapping out my rear axle - Any suggestions? habman Jeep CJ Forum 10 03-03-2003 06:27 PM
