Rear end question for upgrading V8/383 swap in CJ-7. - JeepForum.com
post #1 of 2 Old 06-25-2002, 12:08 AM Thread Starter
JunkJeep?
Post Rear end question for upgrading V8/383 swap in CJ-7.
Ever since my CJ-7 was swapped with a 383 Stroker and TH-350 tranny I feel I should have a larger power distribution to the rear wheels. Not like I want to pop wheelies or anything, but should the rear end gears be changed/upgraded? I run 33 inch tires/ 2 and 1/2 inch lift on an 86 CJ-7. I have a Dana 44 rear end stock, but should this be upgraded? I keep getting told not to alter as this rearend is quite capable and reputable for fairly heavy abuse even behind a V8/ 350 Tranny Swap. I use this Jeep as a daily driver as well as off-road, does anyone have any suggestions as to getting better performance.
JunkJeep? is offline
post #2 of 2 Old 06-25-2002, 04:07 PM
LS1CJ5
1979 CJ5
Post
I had a few Rear end shops tell me the same thing. The widetrack or 1986 44 is the one to have. The 44 is a tough axle. It's center section is behind the Viper and some of the older Vettes. For added strenght I replaced my Ujoint caps for loops. They also said run it till you tear it up, then buy the 60 or 9.
1979 CJ5 LS1, NV4500
LS1CJ5 is offline
jeep rear end with ford rear end swap? jdp492001 Jeep CJ Forum 3 09-19-2009 07:01 PM
best rear end swap? 1morecj Jeep CJ Forum 6 08-23-2009 12:53 AM
rear swap armedsks Jeep CJ Forum 9 04-13-2009 01:37 PM
upgrading amc 20 yoke to u-bolt design-quick question CJ7 Vette Jeep CJ Forum 2 05-27-2006 10:46 AM
cj rear end swap momohunter Jeep CJ Forum 3 08-19-2005 09:38 PM
