Rear-End question 77 CJ5 - JeepForum.com
post #1 of 6 Old 03-21-2014, 05:41 PM Thread Starter
70worm
1977 CJ5
I assume I have an AMC 20? I was putting on new brake lines and noticed a hole in the top of the tube. Does it take a rubber plug, a bolt, or what? I can take a pic if that helps.
70worm is offline
post #2 of 6 Old 03-21-2014, 06:17 PM
jp360cj
1977 CJ7
Post a picture if you can. The 20 has a vent tube that should have a pieceof hose on it and a hole where the brake line coming from the chassis bolts down
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is online now
post #3 of 6 Old 03-22-2014, 10:15 AM Thread Starter
70worm
1977 CJ5
So I reached under and took a pic and I can see the vent tube with fitting hanging down in the back ground. The bolt is where the hole is. I assume that fitting was pressed in at the factory, so what's the best way to fix it?
70worm is offline
post #4 of 6 Old 03-22-2014, 10:18 AM Thread Starter
70worm
1977 CJ5
Another pic
70worm is offline
post #5 of 6 Old 03-22-2014, 10:50 AM
dg6772
You might try jb. weld or something similar.
Dave in Muskegon using JeepForum
dg6772 is offline
post #6 of 6 Old 03-22-2014, 11:53 AM Thread Starter
70worm
1977 CJ5
I might try to TIG it
70worm is offline
